Hi,
I have a divx encoded at 20 fps.
It plays jerky in my standalone. Is there a way to recover the right fluency if I change it to 25 fps (or may be to 23.976, because I don't know the original fps of the dvd they use to encode it)?
Thank you in advance.
Are you certain it is actually 20fps? The reason I ask is that some software will report 25fps PAL as being 20fps if so-called "movie mode" is forced. Changing the setting to "honour pullldown flags" will often restore playback to its correct 25fps runtime.
Thanks for answering.
I'm sure it's 20fps, because it is what Gsopt says.
Where can I change to honour pulldown flags? What I have is a divx. -
Originally Posted by Talayero
I only ever convert DVD to DVD but I have had DGindex report a file as 20fps when it was in fact 25fps. It is all too common for downloaded DivX files to be encoded with the wrong frame sequence which is why I seldom bother with them.
Blu-Ray Player That can be Made Multi-Region, and Plays Divx USB?
By rdinsf in forum DVD & Blu-ray PlayersReplies: 1Last Post: 4th Jan 2012, 07:19 -
NO AUDIO in DIVX files made by sub2divx
By etcohod in forum SubtitleReplies: 1Last Post: 16th Dec 2009, 22:44 -
Divx problems......how do I fix a "stubborn" file?
By Hank Kinsley in forum Newbie / General discussionsReplies: 5Last Post: 3rd Sep 2008, 19:34 -
home made dvd to divx widescreen problem
By mark70725 in forum DVD RippingReplies: 7Last Post: 1st Oct 2007, 03:13 -
Fix Bad Header/Bugs in an .avi divx file
By krisbee in forum LinuxReplies: 3Last Post: 24th Sep 2007, 07:54
