Hiya
I have a VOB File which is appx 4.5GB. When i try to burn to dvd it says i must use an UDF format as the file is larger than 2GB.
Is there a way round this or do i have to split the VOB file up. It is a film so obviously when it plays it needs to be seemless.
Thx
Paul
	Why burn a VOB as data? If you must, try the UDF format as suggested. But a VOB on its own isn't really of much use - it's basically a part of a Video DVD taken out of context.
 /Mats
	Thx for the reply.
 I am trying to burn it as a video. I put the VOB into VIDEO_TS folder and i get a message saying i must use UDF. When I burn as UDF, it burns it as a file, not as a DVD that will play on a standalone DVD player.
 Anymore thoughts ?
 Thx
 paul
	Creating a Video DVD involves quite some more than "putting a VOB file inside a VIDEO_TS folder" and burning this with Nero.
 Try to persuade a good authoring app to accept your VOB as source material for authoring, such as TMPGEnc DVD Author.
 There's a reason why the DVD standard calls for max 1 GB VOB file size. Any real authoring app will split the VOB(s) in 1 GB chunks. Seamless playback is not affected by this.
 /Mats
	Look at the files on a normal DVD video.Originally Posted by paulwilko
 Aside from the VOBs, there are IFO (basically indexes) and a number of backup files.
 Also, DVD VOBs are NEVER over 1 GB. Though on playback they will be seamless if a title extends over more than one VOB.
 Some apps make a video files that are similar to these VOBs, but you can't just dump them to a disc and play them as a video.
 Generally you can treat them as MPEG files.
 One quick, free, way: try ReJig.
 File Mode: demux your VOB, to produce a video and an audio file.
 if that works, then use
 DVD Author mode: select the two files you just made and a folder ("destination"), click "create".
 This will create a complete VIDEO_TS fileset you can burn and play.
	Thx all
 I tried what seemed the simplest (AlanHK)'s method and it worked, so thx for that
 Cheers
 Paul
  Removing VOBs before burningBy drdumont in forum Authoring (DVD)Replies: 1Last Post: 2nd Apr 2012, 19:29
  Best method for splitting up an .avi into various chapters and burningBy aple in forum Newbie / General discussionsReplies: 2Last Post: 21st Jul 2011, 21:24
  Burning VOBs - error "Couldn't find any VOB unit"By kshavo in forum Authoring (DVD)Replies: 7Last Post: 17th Feb 2009, 14:23
  VOB editing before burning (splitting, chapters, etc)By windranger in forum Newbie / General discussionsReplies: 7Last Post: 3rd Nov 2007, 09:29
  Burning options for VOBs??By Akhet in forum Newbie / General discussionsReplies: 1Last Post: 11th May 2007, 18:32
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
