I have a one second PAL event on my timeline and I want to render it out as a still (PNG) sequence. I would expect to get 25 stills (25FPS).When I run the script 'Render Image Sequence' it tells me 'Insufficient step time'. By default the step time is 00.00.00.01. So I increase the step time to 00.00.00.02. This renders out 14 stills!. When I zoom in on the timeline frames it shows 00.00.00.29 just before the 1 second mark. NTSC!. All my project properties are set to PAL DV Widescreen(720x576, 25.000fps). Any idea what I'm doing wrong in not being able to get my 25 PNG's?.
the Render Image Sequence xml may be preset for ntsc -- you would have to edit the xml ....... or
render out to the frame server and import that file into vdubmod and render out images (the way i do it)"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Cannot render to widescreen in neither vegas 7 or 8
By 2prfm in forum Video ConversionReplies: 1Last Post: 7th Sep 2010, 09:38 -
Best render settings for DVD in Vegas
By harishfx20 in forum EditingReplies: 4Last Post: 11th Aug 2010, 02:16 -
Vegas Batch Render?
By duderdude2 in forum EditingReplies: 1Last Post: 28th Feb 2010, 03:42 -
Vegas render question
By wingfan in forum EditingReplies: 2Last Post: 29th Sep 2008, 20:10 -
how do I batch render in vegas 7
By Jorge in forum Video ConversionReplies: 1Last Post: 25th Aug 2007, 20:02
