Ok I have a Creative Zen Vision. it plays a lot of videos but can be pretty picky sometimes.
I have this divx file that it will not play. it says divx not supported but then lists DIVX as supported. Note I typed that carefully it SEEMS its only problem is that the fourCC descriptor has DIVX as divx in lower case and this is enough for it to reject it ???
this is what Vdub shows
http://www.nerys.com/stuff/videoinfo.jpg
here is the error I get
http://www.nerys.com/stuff/odderror.jpg
it literally says the video codec 'divx' is not supported and then says DIVX is supported.
SO I just want to ALTER this file so divx says DIVX and see what happens (its too low res to reconvert)
I found a program called avic that appears to do exactly what I need. It does not. it DOES alter something in the file because when I close it and open it and reload the file it SHOWS the new fourCC code I put in the last time
but Creative still rejects it with the same error and Vdub still shows it as
So how do I change that information ??
Suggestions ?
AHH !! Found it !! abcavi Tag Editor. It did the trick the video is now uploading
yippee. I spent 2 days looking for this. Finally gave up and posted and off course I find it 45 seconds later
go figure
Help with incompatible video format, HDV
By LaMaison in forum MacReplies: 6Last Post: 21st Dec 2009, 05:00 -
incompatible blu-ray video
By mirwais in forum Authoring (Blu-ray)Replies: 14Last Post: 29th Jul 2009, 13:14 -
Can I copy & play from an incompatible DVD format to a compatible one?
By akersaz in forum MediaReplies: 8Last Post: 14th Mar 2008, 19:07 -
Problem converting standalone incompatible clip but keep quality
By Mark69 in forum Video ConversionReplies: 6Last Post: 2nd Feb 2008, 10:15 -
ULead Video Studio output MPG incompatible??
By TJohns in forum EditingReplies: 0Last Post: 27th Aug 2007, 04:05
