any ideas on how to do this? any free ones out there that are good?
Paul
You could try SUPER or MediaCoder - both are free.
Real Media is not a great one for converting.Read my blog here.
I'd advise using Super. There's a really old program called TINRA that can convert RM to AVI, but I don't recommend it. If I remember correctly, it generates uncompressed AVI files from the RM souce - that's if it works at all. Sometimes it doesn't work at all on some sources. Nobody knows why. It's no longer being supported.
RM is usually pretty crappy because the encoders do a lot of nasty things to reduce file size, like dropping frames and using incredibly small resolutions. Don't expect miracles and don't be surprised if your video looks like garbage after it's converted. -
well if you don't recommend converting from ram to mpeg then i guess i'll not bother.
converting .rm real media files to .avi or .mpeg
By tilopa88 in forum Video ConversionReplies: 5Last Post: 25th Jul 2009, 10:45 -
Audio problem when converting a MPEG file to AVI
By Kareng in forum ffmpegX general discussionReplies: 9Last Post: 18th Jul 2008, 18:50 -
By Kareng in forum AudioReplies: 1Last Post: 2nd Jul 2008, 16:56 -
Converting a .ram file to a .wave or an .mp3 file
By bryankendall in forum Newbie / General discussionsReplies: 2Last Post: 1st Jan 2008, 18:17 -
problem converting one little file to mpeg MOV (any ideas why)
By bdaul in forum ffmpegX general discussionReplies: 5Last Post: 1st Jan 2008, 09:32
