I have 2 different videos, of the same file format (.avi) and everything.
How do I merge them together to be one continuous video?
VirtualDub or VD Mod would be my first choice, using 'Direct stream copy'. They have to be exactly the same and no VBR audio.
But if you are merging them to encode to a DVD, it's better not to merge them, just encode them separately and let your authoring program do it. Less chance of sync problems that way.
First-WHY do you want to or think you need to do this? There are many things that can be easily done even when leaving them separate.
Second-"everything" covers a lot of territory (more than you might think). Posting some screenshots of Gspot scans of your files should help ensure the veracity of this claim.
Third-If they're truly pair-able, using the "Append" function in Virtualdub (along with the "DirectStreamCopy" mode to ensure same codec/no re-encoding) should do you well.
There are other options, some batch scripts, some BINARY joiners, that might do this, but they aren't anywhere near as SAFE as what I just suggested.
Scott -
What I want to do is, yes burn them to DVD.
So....what would you reccommend doing?
Question with Panasonic DMR-EH75V...putting videos on hard drive
By tucold in forum DVD & Blu-ray RecordersReplies: 2Last Post: 17th Jul 2014, 14:21 -
Help In Putting Two Videos Into One Screen
By R3CONF1GUR3D in forum EditingReplies: 12Last Post: 13th Apr 2011, 04:20 -
Putting videos of my band on YouTube
By Wild1 in forum Newbie / General discussionsReplies: 4Last Post: 17th Apr 2009, 19:50 -
Conversion usiing VirtualDub - 720 X 560 videos into 640 X 360 videos
By candyman9999 in forum Video ConversionReplies: 1Last Post: 13th Jan 2009, 23:13 -
putting videos on a Nintendo DS
By Al the Killer in forum Newbie / General discussionsReplies: 3Last Post: 10th Aug 2008, 06:04
