Results 1 to 9 of 9
  1. Member crjackson's Avatar
    May 2002
    Charlotte, NC
    I hope I posted this in the right forum, if not then I apologize.
    I just purchased the Denzell Washingtion movie Daja Vu. I ran it through DVDFabHDDecrypter and it seemed to rip well (movie only - engilish subs - AC3 -5.1)
    I put it in my pioneer set-top player and it all looks good until a few minutes before each chapter break.
    Suddenly - I'm looking at directors comments and how the movie was produced. I can skip past that section and go back into the movie where all is fine again. Then suddenly it does it again, and again....
    I've tried several times using different settings but no matter, it always yields the same result.
    Obviously this is some new form of copy protection. What is it called, and what program can defeat it?
    Thanks in advance.
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    Try ripit4me or a trial of anydvd. - also wouldn't hurt to try different brand of blank media.....
  3. Member crjackson's Avatar
    May 2002
    Charlotte, NC
    I'll try rip it for me. AnyDVD never seems to run well on my machine.
    Different brand media has nothing to do with it. It plays the same way on my HD after being ripped.
  4. Originally Posted by crjackson
    Actually, a new copy protection has nothing to do with your problem. Deja Vu has ILVUs. Title 1 is the actual main movie. Title 2 is the movie plus it shows commentary and behind-the-scenes stuff spliced in as you watch. All the rippers I've seen see Title 2 as being the longer title and therefore it gets selected by default. It's the wrong title to make a backup of. Make a backup of Title 1 and you'll have just the movie.
  5. Member crjackson's Avatar
    May 2002
    Charlotte, NC
    Sweet, I'll give this a try tonight or tomorrow. How did you find this out btw?
  6. Originally Posted by crjackson
    I figured it out by watching the DVD and seeing which titles were accessed and when. There have been a couple movies like this so now I always check before backing up my legally purchased DVDs.
  7. Member crjackson's Avatar
    May 2002
    Charlotte, NC
    Thanks again, I'll be on the look out for that from now on...
    Jun 2007
    South Africa
    PSL2
    0:0x36067DCE,0,DEJA_VU_GBR
    1:260,703
    1:2147,2362
    1:2363,2368
    1:2385,6725
    1:6726,6731
    1:6746,8212
    1:8213,8838
    1:8839,56129
    1:56130,56135
    1:56150,78502
    1:78503,78508
    1:262929,263440
    1:263441,263453
    1:263454,266774
    1:266775,266787
    1:266788,266800
    1:266801,357826
    1:357827,360245
    1:360246,381754
    1:381755,384301
    1:384302,488803
    1:488804,493121
    1:493122,515073
    1:515074,521507
    1:521508,525004
    1:525005,609396
    1:609397,610911
    1:610912,629955
    1:629956,647172
    1:647173,662948
    1:662949,709242
    1:709243,709935
    1:709936,715729
    1:715730,793122
    1:793123,809307
    1:809308,811134
    1:811135,828350
    1:828351,861795
    1:861796,870211
    1:870212,886307
    1:886308,888834
    1:888835,892379
    1:892380,1047375
    1:1047376,1154585
    1:1154586,1162121
    1:1162122,1162942
    1:1162943,1175556
    1:1175557,1211990
    1:1211991,1233895
    1:1233896,1248562
    1:1248563,1253081
    1:1253082,1254972
    1:1254973,1401781
    1:1401782,1488583
    1:1488584,1506696
    1:1506697,1507975
    1:1507976,1525294
    1:1525295,1564953
    1:1564954,1571527
    1:1571528,1579071
    1:1579072,1594143
    1:1594144,1599154
    1:1599155,1600368
    1:1600369,1697573
    1:1697574,1825318
    1:1825319,1826746
    1:1826747,1905395
    1:1905396,1959231
    1:1959232,1961647
    1:1961648,1962425
    1:1962426,1972765
    1:1972766,2036634
    1:2036635,2050490
    1:2050491,2085303
    1:2085304,2086878
    1:2086879,2091769
    1:2091770,2191661
    1:2191662,2222134
    1:2222135,2311039
    1:2311040,2335525
    1:2335526,2336512
    1:2336513,2354413
    1:2354414,2408277
    1:2408278,2415685
    1:2415686,2421529
    1:2421530,2456912
    1:2456913,2458691
    1:2458692,2462697
    1:2462698,2547973
    1:2547974,2715200
    1:2715201,2733575
    1:2733576,2734955
    1:2734956,2754859
    1:2754860,2786884
    1:2786885,2794070
    1:2794071,2831984
    1:2831985,2835134
    1:2835135,2838022
    1:2838023,3033851
    1:3033852,3035882
    1:3035883,3075751
    1:3075752,3183765
    1:3183766,3185417
    1:3185418,3208658
    1:3208659,3230962
    1:3230963,3237138
    1:3237139,3244783
    1:3244784,3266964
    1:3266965,3270671
    1:3270672,3272573
    1:3272574,3381907
    1:3381908,3450015
    1:3450016,3613174
    1:3613175,3613180
    1:3613181,3613186
    1:3613187,3613192
    1:3613193,3613198
    1:3613199,3613204
    1:3613205,3613210
    1:3613211,3613216
    1:3613217,3613222
    1:3613223,3613228
    1:3613229,3613234
    1:3613235,3613240
    1:3613241,3613246
    1:3613247,3613252
    1:3613253,3613318
    1:3613319,3613368
    1:3613369,3613447
    1:3613448,3613498
    1:3613499,3613563
    1:3613564,3613593
    1:3613594,3613599
    Aug 2009
    Thailand
    The right way to Rip main movie from Deja Vu.
    1. Use DVDFab to rip only main movie to iso image.
    2. Mount iso with MagicDisc.
    3. Run DVD Decrypter
    Click menu Mode --> File
    Click menu Tools --> Settings
    Click "File Mode" tab
    File Splitting --> By Cell ID
    Check "Multi Angle Processing" and Retain Angle "1" and Click OK
    Choose Destination as C:\Angel1 and press Rip button
    4. go back to step 3 but change Retain Angle to 2
    and change Destination to C:\Angel2
    5. go back to step 3 but change Retain Angle to 3
    and change Destination to C:\Angel3
    6. go back to step 3 but change Retain Angle to 4
    and change Destination to C:\Angel4
    7. Run Vob Blanker
    open VIDEO_TS.IFO from drive we ceate at step 2
    vobblanker will warn about ILV Cell click OK
    look in TitleSet main movie will be Skip click Process button
    look "PGCs IN Selected TitleSet" you will see only main movie click Cell button
    there will be 17 chapters and 59 cells
    These are cells we have to replace
    VID 2 CID 2
    VID 4 CID 2
    VID 6 CID 2
    VID 8 CID 2
    VID 10 CID 2
    VID 13 CID 2
    VID 15 CID 2
    VID 17 CID 2
    VID 19 CID 2
    look in Angel1, Angel2, Angel3, Angel4 Folders and choose the right cell you like
    Click Apply
    Click Process
    and you will get only main movie with correct angle from Deja Vu.
