  1. Hi,
    Is there anyway to do batch transcoding with DVDShrink or any other trasncoding program so I can set it up and run it overnight with no interverntion?
    Thanks,
    Joe
    Aug 2004
    Originally Posted by joelore
    ...or any other trasncoding program so I can set it up and run it overnight with no interverntion?
    Thanks,
    Joe
    DVD Rebuilder Pro has batch capabilities, although I wouldn't consider it a transcoding app like DVDShrink.
  3. Yeah, I use that but I am just looking to do quick transcoding not full re-encoding. Thanks.
  4. Member Soopafresh's Avatar
    Jan 2004
    Aug 2004
    Well actually if you use DVD-RB Pro in rejig mode, which is a transcoding tool, it might be something worth looking into. I've used rejig before and it's a pretty quick, decent transcoder as long as you don't have to compress too much.
