Well,I use NERO,latest version,and my daughter wants me to convert and write an MP3 DVD-r.In most things I AM NOT A NEWBIE,BUT!,there is always one of those,is there anyway that you can add the "albums" of MP3s ,in such a way that they stay in their respective album slots or in the order I add them?As it is now,I add ,say titles 1 thru 18,and then I add the next album of 1 thru 11 and it,NERO,puts all the songs that are 1 together at the top!Now I already thought I could rename them!But that is several 100's of songs.And ,if I keep them in the album folders,the DVD player or CD player will not play them. Any ideas?I have looked and there is no obvious change that can be made to the "preferences" in the NERO software. Thnkyou,BC
I think you should be able to just drag and drop and burn as data. Then it should be playable by any dvd player that reads mp3.
Worth a try... (I have done successfully before but can't remember the program I used).Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Create separate folders - one for each album.
/Mats -
Thanks mats didn't notice that. Yeah the way I make my regular mp3 cds is to take the seperate folders I have for each album and then burn those. So example:
ROOT
----ARTIST
---------ALBUM
Then the mp3s for each seperate album go in to the corresponding folder. Then just drag and drop each artist folder so that the albums inside stay intact.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
I just rip/rename all of my mp3's into a format to control this same issue. I use artist - album - song.mp3.
Then whereever you put/use the files, they stay together. I find this a lot easier than having multiple folders.Google is your Friend
ShowBiz DVD 2 Error - Failure writing the disc
By smbcingu in forum Authoring (DVD)Replies: 4Last Post: 2nd Jan 2011, 16:34 -
Disc writing tool not working in TMPGEnc dvd authoring 4
By egor909 in forum Authoring (DVD)Replies: 3Last Post: 22nd Nov 2009, 05:14 -
TPMGEnc DVD Author 3.0.9.166 crashes on writing to disc
By gayclarke in forum Authoring (DVD)Replies: 4Last Post: 10th Oct 2007, 03:40 -
DVD Writing
By netpicker9 in forum Authoring (DVD)Replies: 5Last Post: 15th May 2007, 23:16
