It doesent support WMV files, but if you rename your WMV file to AVI then it will import and
convert it to divx !! tried a dozen clips works perfect and extremely little loss of quality.
two important things though, this was test on Version 0.3.96 earlier versions gave funny results.
second, choose the VGA(E800) profile as this auto detects the original files resolution( if the
original files resolution is greater the 640x480 then you will need to choose another profile...experiment
Happy Encoding
Phil
From what I remember PocketDivxEncoder uses mencoder for encoding which would mean yes it supports wmv, also means that it doesn't convert anything to DivX since mencoder doesn't support it; only libavcodec MPEG-4 and Xvid.
Convert WMV to AVI / DivX / Xvid
By p_uriel in forum Video ConversionReplies: 5Last Post: 14th Feb 2010, 22:40 -
how to convert wmv to avi for dvd playback[divx support]
By gundja in forum Video ConversionReplies: 4Last Post: 18th Mar 2009, 13:32 -
Converting HD (DivX/MOV/WMV etc) to DVD or DivX ???
By snadge in forum Video ConversionReplies: 32Last Post: 8th Jan 2008, 06:48 -
How to convert wmv clip so its properties match other wmv clips
By sohaibrazzaq in forum Video ConversionReplies: 4Last Post: 4th Aug 2007, 10:16 -
Best Batch convert tool for WMV to DIVX
By hsantos in forum Video ConversionReplies: 3Last Post: 28th May 2007, 09:48
