I have 4 avi. half hour episodes that Im trying to put on one dvd. Im over about 200mb, 4700mb. Is there anyway I can make one less quality so they will all fit.
Is there a software that will allow you to control the video birate and act as creator like neodvd?
Is it easier to make vob files or mpeg2?
Also will adding a menu add mb? Im trying to use neodvd7.
Drop them all into convertxtodvd. it will size them automatically. Or if you have already authored a DVD, use dvdshrink to reduce the size to a burnable disc size.
You are in breach of the forum rules and are being banned. Do not post false information.
/Moderator John Q. Publik -
Yes but not substatially if your just talking still pictures or the basic menu layouts included in stock programs. BUT if you're adding motion menus and custom music and animation then you will add a lot more space and not to mention increasing the authoring time required to make the video_ts folder on the hard drive. The more complex the menu the longer it takes to process. Just a heads up there.Also will adding a menu add mb? Im trying to use neodvd7.
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
So can I convert them from avi to dvd and a menu with neodvd. then resize it with dvd shrink to make it fit onto a dvd. then burn it with nero.
if you have them in avi, just drop all (4) into convertX and author that way
or encode them using VBR set slightly lower than max setting, say 6000 for max and 3000 minimum , the total size of all for episodes show allow for authoring with no modification and be excellent quality, depending on source quality
why can't I make dvd w several half hour shows dvd architect/sonic-
By rr1 in forum Newbie / General discussionsReplies: 5Last Post: 14th May 2011, 13:28 -
Good file size when converting TV DVD eps to Xvid/DivX
By ryangarfield in forum DVD RippingReplies: 1Last Post: 28th Apr 2009, 11:06 -
Archiving TV eps on DVD
By bdizzle in forum Video ConversionReplies: 2Last Post: 17th Nov 2008, 17:25 -
Gotsent Sound Problem! 1st Half 2-Channel 2nd Half 5.1?!?
By Jerec in forum Video ConversionReplies: 1Last Post: 7th Aug 2008, 14:16 -
AutoGK & Half Hour Shows
By Tom Saurus in forum Video ConversionReplies: 26Last Post: 23rd Oct 2007, 12:33
