Hi guys, I need some help with this one. I'm trying to author some vacation footage with no success. Part of it was shot with a DV palmcorder and part of it is some slideshows made with MPEG video wizard. Here is the error I get.
Cheers for your time*** DVDLAB2 Verification Log ***
6 - 3 - 2007 -- 5:29:5
* VMG Verification *
Number of VTS - 2
Number of Menus: 3
Menu 01 - Type - Dummy
Menu 02 - Type - Motion
Menu Video File D:\Documents and Settings\Yiorgos\Desktop\Logo.MPG
Frame size: 720 X 576
Frame rate 3 [1--23.976, 2--24, 4--29.97, 3--25, 5--30]
Aspect Ratio: 43 [43--4:3, 169--16:9]
MPEG Video Type: 2 [1--MPEG 1, 2--MPEG 2]
Chroma: 1 [1--4:2:0, 2--4:2:2, 3--4:4:4]
GOP 1, size - 15643
GOP 2, size - 26993
GOP 3, size - 34142
Menu Audio File - None
Menu Sub-Picture File D:\Hungary 2004\2nd attempt\171940800_tmpsub1.bmp
Picture size - 720 x 480
nMenu cell count - 1
Menu 03 - Type - Still
Menu Image File D:\Hungary 2004\2nd attempt\178834064_tmp1.bmp
Menu Sub-Picture File D:\Hungary 2004\2nd attempt\178834064_tmpsub1.bmp
Number of imported VTS: 0
* VTS Verification *
<<< VTS Number 1 >>>
Number of Titles: 6
Title 01 - Type - ES or PES
Segment 1, Video File D:\Hungary 2004\Budapest.mpv
Frame Size: 720 X 480
Frame Rate 4 [1--23.976, 2--24, 4--29.97, 3--25, 5--30]
GOP 1, size - 273212
GOP 2, size - 214396
GOP 3, size - 301352
Segment 1, Audio File D:\Hungary 2004\Budapest_cut.ac3
No Audio
Segment 1, Subtitle File : None
Title 02 - Type - ES or PES
Segment 1, Video File D:\Hungary 2004\Wien.mpv
GOP 1, size - 291396
GOP 2, size - 266116
GOP 3, size - 38832
Segment 1, Audio File D:\Hungary 2004\Wien_cut.ac3
Audio type: MPEG, Channel: 2, Sampling: 44100, Bitrate: 384000
Title 03 - Type - ES or PES
Segment 1, Video File D:\Hungary 2004\Festival.mpv
GOP 1, size - 227904
GOP 2, size - 232508
GOP 3, size - 208636
Segment 1, Audio File D:\Hungary 2004\Festival_cut.ac3
Audio type: MPEG, Channel: 1, Sampling: 48000, Bitrate: 128000
Title 04 - Type - ES or PES
Segment 1, Video File D:\Hungary 2004\BudapestZoo.mpv
GOP 1, size - 328312
GOP 2, size - 385520
GOP 3, size - 310688
Segment 1, Audio File D:\Hungary 2004\Budapestzoo_cut.ac3
Audio type: MPEG, Channel: 2, Sampling: 32000, Bitrate: 112000
Title 05 - Type - ES or PES
Segment 1, Video File D:\Hungary 2004\ReturnfromFestival.mpv
GOP 1, size - 250824
GOP 2, size - 238868
GOP 3, size - 248944
Segment 1, Audio File D:\Hungary 2004\ReturnfromFestival_cut.ac3
No Audio
Title 06 - Type - ES or PES
Segment 1, Video File D:\Hungary 2004\BudaToWien.mpv
GOP 1, size - 181528
GOP 2, size - 168404
GOP 3, size - 163800
Segment 1, Audio File D:\Hungary 2004\BudaToWien_cut.ac3
Audio type: MPEG, Channel: 2, Sampling: 44100, Bitrate: 160000
Number of Menus: 2
Menu 02 - Type - Still
Menu Image File D:\Hungary 2004\2nd attempt\53334136_tmp1.bmp
Menu Sub-Picture File D:\Hungary 2004\2nd attempt\53334136_tmpsub1.bmp
* Status Messages *
Pre verification fails. Process abort ! - 1998
I have removed the first video (logo) because it was a pal video, with no luck
Audio sampling varies from 32000 to 44100 (and sometimes none listed). they should be 48000 and keep them all the same bitrate within the same VTS. Also, their extension would indicate ac3, but they get identified as mpeg audio -- how were they created
How many VTSs do you have in your tree structure? Are there two, but you don't have any titles in the 2nd VTS
Thanks I hadn't noticed that. As you can see it's 3 years old videos. I followed a guide to convert the audio back then, but I can't remember which program it was. I'll change it, see what happens and let you know.
Edit: I had used BeSweet back then and my main problem was the audio with this one. I never had problems before of that, but this one was a pain..
DVD Lab Runtime error c++ compile.aux?
By dcook in forum Authoring (DVD)Replies: 10Last Post: 29th Aug 2010, 21:46 -
DVD Lab Pro Error
By SirEdward in forum Newbie / General discussionsReplies: 5Last Post: 4th Aug 2008, 16:22 -
DVD Lab Pro Error b4 compiling
By _yoyo in forum Authoring (DVD)Replies: 1Last Post: 20th Apr 2008, 18:39 -
DVD Lab Project error
By peterhun in forum Authoring (DVD)Replies: 8Last Post: 8th Jan 2008, 19:35 -
dvd lab pro audio error
By tomoftenville in forum Authoring (DVD)Replies: 7Last Post: 6th Dec 2007, 16:05
