I have a 1080i MPEG I am trying to convert to something smaller. I first tried Windows Movie Maker in Vista. I tried outputting it as both 1080p and Xbox 360 HD, both times the video output was very choppy, like it was missing frames. After that, every program I tried wouldn't even load the video. I tried Nero Recode, Xbox 360 Recode, and a couple other. Please help, I really need to get this file smaller.
Reboot your PC. Run a Quickstream Fix on your Mpeg file with VideoRedo. Try again.
Or, convert like this https://forum.videohelp.com/topic329377.html#1702550 -
Hi fearmyrage,
How did you obtain the 1080i video ? .. HD tuner capture card or something else ?
If by chance it was by the WinTV-HVR-1600 hd tuner card, then you have a slight
situation there. VideoReDo 's [Fix] function might help resolve this. But, that will
depend on how bad the HVR-1600 initially headered the file. If you get a black
screen.. ie, in WMP (on my XP Home OS, it's WMP) then this is a corrupted header
in the mpeg and needs to be fixed or patched to get it working inside popular editor/
players.
-vhelp 4294 -
If you captured mts or mt2s files from a hd camcorder, you are going to need something more powerful than what you are using. At the moment, Sony offers AVCHD editing in Vegas 7.0e. AVCHD is Sony's own mpeg4 or mt2s file. Mts files produced in say Panasonic or Canon hd camcorders will need something like new versions of editing software that claim to edit hd files. It will be a while before hd files from Sony hard drive camcorders have a good choice of editing software. If you have captured from another source, you need to either post the file type or upload the file. I am not real fan of converting files to allow editing.
Converting VOB's to MPEG 2
By HitTheRoad in forum Video ConversionReplies: 9Last Post: 9th Aug 2011, 04:46 -
Having problems converting FLV to mpeg with Freemake video downloader
By sarbot in forum Video ConversionReplies: 10Last Post: 11th Sep 2010, 21:41 -
converting MPEG-TS to MPEG-PS (from a Noontec V9)
By ninereeds in forum Video ConversionReplies: 2Last Post: 28th Jul 2010, 10:17 -
Quicktime parse error converting mpeg-1 muxed to DV or mpeg 4
By jglass in forum Newbie / General discussionsReplies: 0Last Post: 15th Jun 2008, 20:51 -
This is a minefield! (converting mpeg to mpeg for DVD)
By uth in forum LinuxReplies: 29Last Post: 18th Nov 2007, 15:04
