My USB Drivers dont regonice any USB Devices anymore! I had to reformat my desktop b/c it was not running smooth and a lots of spywares- yes i had an anti-virus program- i had my printer, ext. hard drive connected to the USB ports and they worked fine, but after the doing a system recovery, if connect any USB decive it does not regonice it, even my plug-n-play USB flash drive doesnt work, it did before.
What mother board are you using? Normally you install the USB, sound, etc. drivers from the CD that came with the motherboard.
http://www.kiva.org/about -
Go to 'Control Panel>System>Hardware>Device Manager>Universal Serial Bus controllers'. You should see some Host Controllers, USB Root Hubs. If you have USB 2.0, you should see a 'Standard Enhanced PCI to USB Host Controller' or similar. 'Enhanced' tells you it's USB 2.0.
If you see none of those or a yellow check or question mark by them, they are not installed or not working.
Since they are part of Windows, I don't know why they wouldn't appear there or be installed.
EDIT: edDV, good point. I had assumed he installed the motherboard drivers.
A restore CD from the original PC manufacturer usually will include the drivers but they are probably obsolete for a P4 2.4GHz. Get the new drivers from the motherboard or computer manufacturer.
Uninstall USB ports in Device Manager, then reboot and let XP reinstall them.
Reliable USB capture devices?
By slats7 in forum Capturing and VCRReplies: 21Last Post: 11th Mar 2012, 20:32 -
PowerDirector 8 doesn't work with USB capture devices
By chris18 in forum Capturing and VCRReplies: 0Last Post: 10th Feb 2010, 07:28 -
USB capture devices vs USB tuner devices...... which are better for recording?
By True Colors in forum Video Streaming DownloadingReplies: 1Last Post: 31st Jan 2010, 16:04 -
USB devices not accessible using Explorer
By mats.hogberg in forum ComputerReplies: 4Last Post: 24th Sep 2007, 16:22 -
usb devices on a network
By lordhutt in forum ComputerReplies: 6Last Post: 6th Jul 2007, 22:49
