I know converting anything from WMV in Macintosh is difficult, but I'm looking for software that will covert high-resolution WMV to Xvid-encoded AVI (or, barring that, Xvid-encoded MP4). VLC can read at least some WMV videos, but according to the popup that comes up when I attempt transcoding, VLC is very good at transcoding and I don't think Xvid is an encoding option.
I'm also wondering about software I can use to convert DivX-encoded AVIs to Xvid-encoded ones.
Let me know,
Peter
Results 1 to 12 of 12
Divx to Xvid: ffmpegx.
(possibly also Visual Hub, but haven't had a need to try it)
some WMV to AVI: Flip4Mac Studio.
has problems with ( naturally) WM 11, and some WM 10,
but handles WM 9 very well to AVI, hadn't had any issues."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
Originally Posted by pgwerner
I'm also wondering about software I can use to convert DivX-encoded AVIs to Xvid-encoded ones.Jean-Philippe Schuck
Un générique, un autre jour, le blog sur les génériques de dessins animés -
I'm looking now for a converter that enables me to convert .wmv files into .avi files, but I haven't been successful yet. By reading a lot of comments and postings I got the impression that it's nearly impossible to get a freeware program for mac os X that can handle wmv files. Is that so? I would also accept a trial version, it's not much that I have to convert, so I don't need the program for long, but it's quite important. All the trial versions I had a look at just would have allowed me to convert up to 30 seconds of the file.
Really hope you are able to help me. -
Originally Posted by Anicsi
A - Installing mplayer and checking if the file is playable
1/ Go to the MPlayer Headquarter and download the latest Mplayer for MacOSX (I mean the application with a GUI, not the binary for ffmpegX)
2/ Check if your file plays fine in mplayer OS X. If not, I'm affraid that there will be no solution.
B - Converting the Windows Media file to raw video and audio files
1/ Locate Mplayer for OS X
2/ Right-click (or control-click) on the application and choose "show package content"
3/ Go to Contents > Resources > External Binaries
4/ Choose the right mplayer for your platform (mplayer_intel for Intel based Macs ; mplayer_ppc for G4 or G5 : mplayer_noaltivec for G3)
5/ Right-click (or control-click) once more on the element and choose "show package content"
6/ This time, go to Contents > MacOS ; you will see the mplayer binary that we will use for the conversion.
7/ Open a terminal window and drop on it the mplayer binary that you found step 6
8/ Drop the video file you want to convert
9/ Type "-ao PCM -vo yuv4mpeg" folllowed by a space
10/ Type "-fps" followed by a space, then type the framerate number of your video (usually 23.976 , 25 or 29.97 ; mplayer is international : it doesn't matter if you use stops or commas) ; this step is not mandatory but can prevent some synchronization issues in case of variable framerate videos
11/ Your final command should look something like this
Code:/Applications/MPlayer\ OSX\ PPC.app/Contents/Resources/External_Binaries/mplayer_intel.app/Contents/MacOS/mplayer video_to_convert.wmv -ao null -vo yuv4mpeg -fps 23.976
12/ Your output files (stream.yuv and audio.wav, I think) are in your home folder. Check with mplayer if this file are OK (please note that raw .yuv files doesn't have any index so you can't jump to any part of the movie).
13/ The YUV and WAV file can now be converted each in turn, then muxed together (->tools) with ffmpegXJean-Philippe Schuck
Thank you very much for the excellent explanation. I don't have any time to take care of that problem at the moment but I will definitely try it. Then I'm going to tell you the result (or maybe I will even need more help
Well I tried today what you told me to do with my wmv files. Everything worked fine (I guess) but i didn't get a .wav file in step 12.
My final command (and the finished process) looks like that: (I've marked the parts i'm not sure about)
p54994025:~ Anna$ /Volumes/MPlayer/MPlayer\ OSX.app/Contents/Resources/External_Binaries/mplayer_noaltivec.app/Contents/MacOS/mplayer /Users/Anna/Desktop/fertigeProjekte/Video\ Dateien/Sarajevo4.wmv -ao PCM -vo yuv4mpeg
MPlayer dev-SVN-r25648-4.0.1 (C) 2000-2008 MPlayer Team
CPU: PowerPC
Playing /Users/Anna/Desktop/fertigeProjekte/Video Dateien/Sarajevo4.wmv.
ASF file format detected.
[asfheader] Audio stream found, -aid 1
[asfheader] Video stream found, -vid 2
VIDEO: [WMV3] 640x480 24bpp 1000.000 fps 1900.0 kbps (231.9 kbyte/s)
Clip info:
author:
copyright:
comments:
Using (default) progressive frame mode.============================================= =============================
Requested video codec family [wmv9dmo] (vfm=dmo) not available.
Enable it at compilation.
Requested video codec family [wmvdmo] (vfm=dmo) not available.
Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
[wmv3 @ 0xa04e30]Extra data: 8 bits left, value: 0
Selected video codec: [ffwmv3] vfm: ffmpeg (FFmpeg WMV3/WMV9)
Opening audio decoder: [ffmpeg] FFmpeg/libavcodec audio decoders
AUDIO: 44100 Hz, 2 ch, s16be, 160.0 kbit/11.34% (ratio: 20005->176400)
Selected audio codec: [ffwmav2] afm: ffmpeg (DivX audio v2 (FFmpeg))
Could not open/initialize audio device -> no sound.
Audio: no sound
Starting playback...
VDec: vo config request - 640 x 480 (preferred colorspace: Planar YV12)
VDec: using Planar YV12 as output csp (no 0)
Movie-Aspect is undefined - no prescaling applied.
VO: [yuv4mpeg] 640x480 => 640x480 Planar YV12
V: 204.5 5075/5075 56% 14% 0.0% 0 0
Exiting... (End of file)
p54994025:~ Anna$
2. you said step 11 was additional, i would have typed it, but where can I look up the framerate number?
Thank you very much for helping me out once again -
1. No. PCM should automatically sets the output to the mathcing values (bits, sampling rate and channels). The audio stream seem to be not recognized. Does the movie clip play fine in Mplayer ?
2. You can check the framerate in Quicktime Player if you have installed the flip4mac WMV components.Jean-Philippe Schuck
YOu can stil try to do a separate audio conversion (after a succesful video conversion) by simplifying your command line to :
Code:/Applications/MPlayer\ OSX\ PPC.app/Contents/Resources/External_Binaries/mplayer_intel.app/Contents/MacOS/mplayer video_to_convert.wmv -ao PCM
I stumbled upon this by accident. use RAD Video Tools by Bink and Smacker. It is pretty straight forward. Load your file and then press convert, push ok and choose from a list of codecs, push convert. Simple!
http://www.radgametools.com/bnkdown.htm
NOTE: Be careful that you don't say no compression because it can easily turn a 10 mb file into a 2GB one. It happened to me -
Convert WMV to AVI / DivX / Xvid
By p_uriel in forum Video ConversionReplies: 5Last Post: 14th Feb 2010, 21:40 -
WMV to Xvid or Divx
By glenn71x in forum Video ConversionReplies: 3Last Post: 15th Jul 2009, 15:27 -
Playing HD (.mkv) and XViD\DiVX (.avi, .wmv)
By yonyz in forum Software PlayingReplies: 10Last Post: 25th Feb 2009, 13:18 -
Intermediate codec and xvid question, and xvid to wmv.
By ^xRun^ in forum Video ConversionReplies: 9Last Post: 22nd Jul 2008, 17:13 -
Converting WMV to divx/xvid
By mattr in forum MacReplies: 1Last Post: 3rd Jan 2008, 09:23
