Hi, I'm using Winfast Palm Top TV Tuner to capture my favorite sports events. I've been told to use interlace capturing to achieve best results. But I can't find the option to turn off the deinterlace function.
Virtualdub can do interlace capturing but it doesn't have the schedule function, I need to do capturing while I'm away from my PC. Virtualdub VCR has the scheduling function but it can't recognize my Tuner, so does Virtual VCR.
So I kinda bump the walls here, anyone got an idea to work around this situation?
Thx in advance
I've tried Winfast PVR2, but the there's no audio, dunno how to fixed this
Hi quanz, to answer the first question you should install the newest version as it has the option to record in Progressive and Interlace.
Yes that is true if you want to burn your footage back to DVD. But if you just want to watch the footage on the computer i would just stick to progressive (less strain on the eyes u wont notice any quality loss unless you have a extreamly picky eyeI've been told to use interlace capturing to achieve best results
the winfast audio really puts the quality of this product down. It has excellent video quality (especially if you want to capture unprotected DVD's, PS2,Xbox,PS3,360 etc), it looks exaclty the same as it is outputed (S-VIDEO recommended). Sorry back to the topic, to fix this minor audio issue check if you have connected the sound plug which is attached to the card inside the computer. If this is already done and it still doesnt work, there should be an option in the audio box located somewhere in the winfast pvr settings called CD/video in choose that option and the same for the other audio box.there's no audio, dunno how to fixed this
hope that solves the problem
Any OTHER S/W for Capturing a DH-PVR?
By Randall_C in forum Capturing and VCRReplies: 6Last Post: 22nd Oct 2009, 12:55 -
WinFast PVR captures audio in PCM only
By jaceko in forum Capturing and VCRReplies: 4Last Post: 13th Sep 2009, 16:24 -
Capturing DV tape to PC, need to interlace video
By nashmarkt in forum Capturing and VCRReplies: 5Last Post: 12th Jul 2009, 16:07 -
winfast PVR -avi
By sg999 in forum Capturing and VCRReplies: 0Last Post: 12th Dec 2008, 12:13 -
Connect Winfast PVR 3000 via CD-In 4-pin on SB X-Fi Titanuim Fatality...
By retroborg in forum ComputerReplies: 2Last Post: 11th Oct 2008, 16:33
