I converted an 173mb .avi divx episode to h264 using SUPER with this guide http://www.dvd-guides.com/content/view/143/59/
I followed the instructions verbatim but my h264 file is 10mb larger than the .avi file. I know h264 is supposed to be smaller so I'm not sure why it's actually larger than the original .avi.
The .avi bitrate was 1009kbps so I chose 960.
I kept the same resolution.
Frame rate was 23.976 so I chose 23.98.
I kept the audio the same at 48khz, 128bit, 2 channel.
Any thoughts?
Bitrate is bitrate!
You can get better compression with h264 but you haven't compressed.
1009kbps -> 960kbps is the same.
Super is doing a single pass encode.
Can't expect a single pass encode to be on target...
Check your target and you'll see super has overshot a little.
Audio bitrate is probably not hit either btw.
lower target video bitrate
p.s. ahh and i don't think directshow should ever be ticked. -
I personally don't think you will see enough of a reduction in file size to justify the loss in quality of another conversion. Unless you have to convert to meet specs for a specific use, I'd leave it as it is.
Google is your Friend
MPEG Streamclip MPEG-TS to MPEG4/H264 (file size & aspect ratio query)
By Heathy65 in forum Video ConversionReplies: 5Last Post: 4th Apr 2012, 12:31 -
PowerDirector makes final DVD files, size larger than mpg file's size, why?
By Xor2 in forum Authoring (DVD)Replies: 4Last Post: 22nd Dec 2011, 18:29 -
MP4/h264 Exact File Size Encoding
By Trismegistus in forum Video ConversionReplies: 1Last Post: 23rd May 2010, 09:57 -
H264 File Size versus Quality
By SCDVD in forum Newbie / General discussionsReplies: 12Last Post: 9th Apr 2008, 14:16 -
2 Small-ish AVI -> 1 Larger AVI = HUGE File. Why?
By cxp36 in forum Newbie / General discussionsReplies: 2Last Post: 6th Mar 2008, 18:31
