Is it possible to edit font used in VobSub (.idx+.sub)?
You can however change the colours and positions by using Subtosup, then opening the Sup in DVDSubedit.
You can change timing and delete subs too. -
And then you must convert back to VobSub. And also you need an IFO file for DVDSubEdit...
Or you can do all these in SubtitleCreator.
If it's only the colors and the timings, you can also edit the .idx file with notepad (see the "palette: " line).
Cheers
Manusse
Why would subtitle font change in conversion?
By Djard in forum SubtitleReplies: 6Last Post: 25th Apr 2012, 19:07 -
Burn subtitle and change font size
By Nazarenojr in forum ffmpegX general discussionReplies: 8Last Post: 14th Mar 2011, 05:25 -
VobSub and editing font properties
By elmuz in forum Newbie / General discussionsReplies: 3Last Post: 28th Sep 2010, 05:30 -
How can i change font subs at KMPlayer?
By eliqush in forum Software PlayingReplies: 1Last Post: 12th May 2010, 17:44 -
Change font in subs...
By tektaktyks in forum SubtitleReplies: 4Last Post: 5th Jul 2007, 11:39
