I bought a new-ish Philips SPD2413BD a couple of weeks ago. It seems to work fine with everything except mini DVDs (DVD-R) from a Sony dvd camcorder. Most software won't recognize that there's a disc in the tray. Nero was able to copy it for me onto a larger blank DVD, but I want to consolidate the video from several mini-discs to normal DVDs (3x the capacity).
No software I tried, except Nero, would even recognize the disc. Not DVD Decrypter, not XP itself (SP2), not even Iso Buster (which I thought was really strange). I would normally attribute this to bad hardware, but Nero was able to copy the video off of it. Also, none of my media player software was able to play the video from the mini disc. Not even Nero would do that, nor would WMP or PowerDVD. Maybe that is a codec problem, but if it's standard book DVD video then it should work, right? The drive does play regular full-size DVDs (both home made and store bought).
The drive is a re-badged Liteon LH-20A1P according to a post at Club CD Freaks, and the LH-20A1P is covered here in the videohelp lists. I have about 2 weeks to RMA it if it's a bad unit.
Any thoughts or suggestions?
Sounds like the camcorder is recording in a proprietary format, which isn't all that uncommon. What file extension is it using?
If Nero can read it, why not just copy it onto your HDD. Then find a way of editing/joining/converting for output onto normal DVD.Google is your Friend
Philips DVDR3576H/37 - Burned Discs Won't Play in Xbox, PC DVD Drive
By jbd5010 in forum Capturing and VCRReplies: 18Last Post: 20th Mar 2011, 04:11 -
Philips DVP5960/37 Won't Read Discs
By synchro505 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 3rd Aug 2007, 02:57 -
DVD won't read...won't create avi thumbnails
By ru5ty in forum DVD & Blu-ray WritersReplies: 6Last Post: 27th Jul 2007, 21:04 -
DVD drives won't recognize any discs
By TIBGustaf in forum DVD & Blu-ray WritersReplies: 10Last Post: 3rd Jul 2007, 08:29 -
pioneer 510H will burn but won't read unfinalized discs
By nixie in forum DVD & Blu-ray RecordersReplies: 10Last Post: 6th Jun 2007, 19:25
