    Jun 2007
    I have taken a video off of You tube and now have it in FLV format, I'm hoping to put the video on Final Cut Pro and blend it with other video i have taken, anyone know of a way I can do that? (I havn't been able to find any FLV codec for Mac and I can't find a converter which changes FLVs into other files.)
  2. riva flv encoder is the key man
    Jan 2007
    i have used super to covert youtube flv videos
    most are 320*240 and iconverted for my phone or email NOT to enclude with anything else
  4. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Somewhere on VideoHelp...
    The OP is on a Mac, so that may not be an option. (Same goes for SUPER.)
    (Fate26: OS X 10.8? Heh.)
    I'm not sure, but Perian might be able to handle FLV1/VP6(2). I haven't tried it. Also, you can try VLC and ffmpegx for conversion.
    Jun 2007
    I have already checked out perian and VLC neither of them seem to cover it, I'll take a look at ffmpegx though and see what it can do.
    P.S. I fixed my O.S. :P
    Apr 2005
    Blacksburg, VA USA
    iSquint (free at isquint.org) will generally convert a uTube video
    to MP4 format, even "optimize" it for iTunes/iPod. If it doesn't
    work, or if you want another output format, try its big brother
    VisualHub (same location).
    Al Bloom
    Jun 2007
    Success!
    Visual Hub works perfectly; it can set it up directly for final cut pro. Thanks for the help
  8. Member terryj's Avatar
    N35°25.24068, W097°34.204
    Perian 1.04 ( which is in Beta now) improves FLV support.
    I've been using it with many FLVs from VMix and YouTube
    in my vidcast, and it works very well.
    It also is handling MKVs darn well too I might add.
    "Everyone has to learn, so that they can one day teach."
    When I'm not here, Where can I be found?
    Urban Mac User
