I have a problem with converting a rmvb file in convertxtodvd, in the preview windows its green, i have tried to download the newest version 2.2.1.253, i have downloaded dll files drv23260.dll, drv33260.dll, drv43260.dll, Pncrt.dll
its still green screen, anyone know how to fix this? i also have k lite mega codec pack
you have to download certain dll file from real media and put them in the the convertxtodvd.exe directory then it will convert rmvb files.
http://www.portmac.com/modules.php?name=Downloads&d_op=getit&lid=197 -
i already downloaded the dll files, like i said in the first post
realmedia files:
drv23260.dll, drv33260.dll, drv43260.dll, Pncrt.dll -
RMVB is one of the more difficult formats to convert as it is very propitiatory and Real doesn't just give out the codecs. Some sites have came up with workarounds to decipher the format, but it's not always easy. Generally the 'green screen' effect means you have a codec problem.
BTW, you mention K-lite. From long experience on this forum and other places, that may be your main problem. K-lite has a well known history of damaging good codecs and replacing them with corrupted or older or incompatible ones. It is also very difficult to remove without damage to your system, sometimes needing a reinstall of Windows to clean up the mess.
Do a 'all forums' search for 'K-lite'.
And welcome to our forums.
Convertxtodvd causing Computer Blue screen
By jbitakis in forum Authoring (DVD)Replies: 14Last Post: 29th Nov 2012, 12:46 -
Avidemux Green Screen
By FrozenInferno in forum Video ConversionReplies: 4Last Post: 2nd Apr 2011, 22:31 -
Underwater Green Screen
By kccannon in forum EditingReplies: 6Last Post: 21st May 2009, 19:35 -
Funny green screen
By timmythesaint in forum Newbie / General discussionsReplies: 18Last Post: 14th Apr 2009, 14:41 -
green screen when capturing
By HDMI in forum Capturing and VCRReplies: 1Last Post: 30th Jul 2007, 11:37
