Each time I compress a half hour project in compressor (the version included in FCS 1) it says it will take an hour, but it actually takes 3 or sometimes 4 hours. I have a dual G5 with 2gigs ram, blah blah blah. Anyone know why it takes longer than it says?
Do you add filters to the process? Anytime you do more than a basic conversion the time really adds up.
Also ;are you doing any other labor intensive tasks while its running? See if it still takes that long if you simply close all other applications and leave just the video app running.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
is your Ram 3rd party or is it Apple Ram?
what are you compressing from and to?
Is it from FCP generated Quicktime files,
or is it direct from FCP's timeline?
If from FCP's timeline, as Yoda said, how many filters,
transitions, audio effects, Motion effects, etc?
The steps I take to shorten my renders:
1. Export out of FCP to a Quicktime file, thus
"flattening" many of my effects and transitions.
2. Stick with One Pass over two pass for most projects.
3.make sure to not run any other CPU intensive items
or apps at the same time as Compressor. YMMV.
also see here:
Apple Compressor Time to actual job completion"Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User
How old are you (no lying now)
By Craig Tucker in forum PollsReplies: 354Last Post: 19th Oct 2020, 19:52 -
External HDD - standing or lying down
By uno in forum ComputerReplies: 4Last Post: 29th Jun 2011, 16:06 -
How old are you - part 2 (no lying now)
By yoda313 in forum PollsReplies: 95Last Post: 4th Oct 2009, 10:00 -
Virtualdubmod is lying
By zinc in forum Video ConversionReplies: 12Last Post: 12th Jun 2008, 11:54 -
Either people are lying or something is up!
By 1magus in forum DVD RippingReplies: 3Last Post: 25th Jul 2007, 03:40
