Hi there,
I have a Dual Layer dvd recorder (stand alone), and it records fine and play back is great. But when I burn a Dual Layer DVD on my PC, it doesnt play back, on any of my dvd players (which do have DL playback).
Im using Nero Burning Rom 6. It kind of reminds me of when you forget to finalize a disc on your recorder, it wont play on other players. But this problem is weird, im sure im doing everything right (burning exactly the same as i would with a Single Layer, and changing the size of the disc on the bottom of Nero.
Any ideas? Thanks heaps!
don't use nero. And use only verbatim dl discs
What We Do In Life, Echoes In Eternity.... -
I have had no problem using Nero 6.6 to make data disks. I had better luck = No problems burning +R DLs with imgburn when I make a standard DVD Video.
Process was capture video, author only, no conversion in TDA, with TDA 3, Burn with imgburn using imgburn to set the layer change. On the TDA3 authored it gave a wide range as they were only 6Gig or so. Playback was fine.
I did have problems with Nero and Video DVD Dls. Divx on Dls works with Nero not sure what it is doing.
burning mkv file and separate srt file to play on dual layer disc
By julie_152 in forum Newbie / General discussionsReplies: 1Last Post: 29th Sep 2009, 11:26 -
dual layer disc
By sicperv in forum DVD RippingReplies: 2Last Post: 25th Feb 2009, 11:11 -
data on dual layer dvd disc......
By dvstorm in forum MediaReplies: 4Last Post: 23rd Feb 2009, 19:21 -
Dual layer disc error (2nd layer not burning properly - AVCHD)
By hhhgamewmx7 in forum Authoring (DVD)Replies: 7Last Post: 24th Aug 2008, 09:00 -
Disc copy of a dual layer disc
By kingjames in forum Newbie / General discussionsReplies: 3Last Post: 1st Oct 2007, 13:52
