    Dec 2005
    Asia
    We just edited some home Dv on premire pro
    and the output looked great on the computer
    but when screened the DVD on the TV all [and only}
    pans looked jumpy...
    What can I do ??? why ?
  2. Member gadgetguy's Avatar
    Feb 2002
    West Mitten, USA
    My guess from your description is that the footage received from your camcorder was Bottom Field First and you encoded it as Top Field First (or vice versa). I believe it's possible to change the field order flag without re-encoding, but I don't know the name of the application that will do it. In the future you will want to pay attention to the field order and set your encoding properties accordingly.
    Buy My Books
  3. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    DV is always bottom field first.
  4. Member stars's Avatar
    Apr 2006
    In the Lighthouse
    Hi use ReStream to fix the problem
    stars...
  5. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    Just so the OP is aware restream is for fixing a MPEG that has alreadfy been encoded. If you set the right field order to begin with you don't need it.
  6. Member gadgetguy's Avatar
    Feb 2002
    West Mitten, USA
    Originally Posted by thecoalman
    ... If you set the right field order to begin with you don't need it.
    Which is why I didn't know the name of the program to fix it.
    I might also add that although DV from a camcorder starts out as BFF it doesn't necessarily follow that the edited video should be encoded BFF. It depends on what happens during editting.
    Buy My Books
  7. Member stars's Avatar
    Apr 2006
    In the Lighthouse
    If you have the wrong field order the the picture should jump here and there not only in the pans.
    The strange thing is that , only the pans looks "jumpy", the effect is more visible
    when the pan is slow..
    I may not have an answer to the problem but here are some hints...
    If your source DVD is NTSC and viewed on a PAL system often the pans a "jumpy"
    and the other way around PAL source is jumpy on a NTSC system..
    Check how permier pro encodes your DV video...
    I have also noticed that if you have a source that use 23.976 fps and you encode it
    with pulldown function to get 29.976 fps NTSC progressive, this "jumpy" effect will show...
    I have been looking around this forum for a real tecnical answer but havent found one...
    This is my own experience as a result of testing with different sources..
    stars....
    Your video might have been imported wrong. Premiere often insists my source is bottom-field, and I have to change the source settings.
