Results 1 to 11 of 11
    May 2007
    I have a Dell Dimension 2350 with almost a gig of ram now but when I try to download my videos from my Sony HDR-UX1 my display corrupts. Dell sent me the latest drivers for it but they were older than the ones I have.
    Any help?
  2. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Any help?
    This is an AVCHD camcorder. That means the file is MPeg4 AVC.
    Corrupts during download or when you try to play the file?
    If playback what are you using to play the file?
    May 2007
    My display corrupts when I am downloading the videos I have made and won't allow me to finish the process.
  4. Member edDV's Avatar
    Mar 2004
    Odd that. You can access your files off the DVD.
    May 2007
    When I plug in my camera it pulls up a Sony program and starts to download them. When it reaches about the fourth one my display goes funky.
  6. Member edDV's Avatar
    Mar 2004
    I'd call Sony support.
    May 2007
    I have they told me to call Dell.
  8. Member bendixG15's Avatar
    Aug 2004
    Sounds like they left the fixit process up to you.
    I would just try to download on a diferent computer
    and based on those results I would chase Dell or Sony.
    May 2007
    I have slept on it and have come to the same conclusion. I think I will buy a new PC and download on it. This one is four years old anyway(antique)! Thanks for the help.
  10. Member edDV's Avatar
    Mar 2004
    I'd suggest something other than Dell or Sony.
    Jul 2007
    I had similar problems with hdr ux1. Bought an external pioneer usb dvd burner and it works fine with the ux1 discs. i also have a dell dimension, 3 ghz pentium 4 with a gig of ram. curious what you ended up getting and how it handles avchd using picture motion browser or editing software. Kevin
