I accidentally extracted tracks from a larger wav file to PCM format instead of WAV using CDMage. I have since deleted the original large wav file so I can't redo it choosing wav format. Does anyone know how to convert the PCM files to Wavs?? I have tried some conversion progs such as DVDLab Pro but the resulting wav file is just noise. Any help appreciated.![]()
That DVDLab tool should work.
Where did the ORIGINAL WAV come from--CD? DVD? Internet?
If CD, the WAV should have been Stereo, 16bit, 44100Hz.
If DVD, the WAV should have been Stereo, 16bit, 48000Hz (although there are other options here).
If Internet/elsewhere, it could be one of a bunch of different types...
When converting in DVDLab, try doing it once as suggested, and then once using the "Swap High & Low Bytes" checked. This is often the cause of what people refer to as "noise" in the file.
decode 5.1 matrix surround wav file to 6 mono wav files
By Zerrax in forum AudioReplies: 2Last Post: 24th Nov 2013, 07:39 -
Transcode 7.1 DTS-Master Audio to 7.1 L-PCM (.wav/.aiff)
By nateo200 in forum Blu-ray RippingReplies: 10Last Post: 27th Apr 2012, 15:57 -
Are Wav audio and PCM audio the same thing?
By yoda313 in forum AudioReplies: 2Last Post: 22nd Mar 2009, 15:46 -
M2V + 2 WAV files to VIDEO_TS with 2 PCM soundtracks (not mp2)
By cleantone in forum MacReplies: 14Last Post: 28th Aug 2008, 15:10 -
PCM WAV file bitrate too high?
By djdust in forum AudioReplies: 1Last Post: 19th Feb 2008, 15:05
