Hello all,
I need to download an older version of Java .. 1.3 specifically. I did a google search and I got a lot of hits .. but for stuff like Java SDK and Java JDK, etc, etc.
Admittedly, I dont know too much about Java so I am not sure if any of these are "good" links for a Win XP version of Java 1.3.
Would it be possible for anyone to provide me with a link to download Java 1.3 for Win XP?
It would be GREATLY appreciated.
LG
The link below is to both Java 1.3 SDK and JRE:
J2SE v 1.3.1_20
http://java.sun.com/products/archive/j2se/1.3.1_20/index.html
If you need anything Java you should go to Sun's site, that's where you will find what you need.
Unless you are writing programs in Java, you will only need to download the JRE (Java RunTime Environment). The JRE allows you to run Java programs. The SDK is the development environment used to write Java programs.
More information about Java can be found at Sun's site http://java.sun.com
Cheers -
Thanks a ton RLT.
I WAS at the Sun site but with my very limited knowledge of Java, all those extra letters through me off. I didnt realize that JRE was just the regular runtime environment (however now that I know what it stands for, the acronym makes perfect sense haha).
Anywho .. I very much appreciate the time.
Thank you,
LG
Java certificate: security alert
By themaster1 in forum ComputerReplies: 2Last Post: 20th Apr 2012, 07:49 -
Stream MPEG2 file in JAVA
By PCNG in forum ProgrammingReplies: 1Last Post: 6th Oct 2011, 04:16 -
ProjectX Java error
By kimse in forum EditingReplies: 8Last Post: 14th Sep 2008, 16:44 -
question about java download
By jimdagys in forum ComputerReplies: 7Last Post: 5th Oct 2007, 05:48
