First off I'm on a Mac.
I know this may be a Noob question ... but I'm very new to the whole DVD burning thing ....
Okay ... here's my problem.....
I have a .avi file (two actually) that I wish to Burn on to DVD, but it only plays with sound in VLC. In the other programs I've playd it in there is no sound (Quicktime, Divx Player, iDVD)
I don't care about it not working in QT and DviX, but I wish to burn it and there is no sound durign the preview in iDVD. Now I've read some things about a program called Burn? maybe I should try this? Does it work well with codecs? or maybe the video will encode itself fine when I burn it ...
I'm asking if anyone has any experience with this? thanks soo much in advance for any help or advice!!
Mikesmith
VLC uses it's own codecs, so the fact that the videos play in VLC, would seem to indicate the files are fine. Most likely, your other players are missing a codec or it is corrupt.
Just try the conversion and burning with whatever software you normally use (or new software for that matter), and then burn on an -RW disc. Then if it doesn't work, you can reuse the disc.Google is your Friend
iDVD Created DVD without Sound on DVD Players
By Doctor X in forum MacReplies: 13Last Post: 12th Mar 2011, 04:51 -
IDVD themes
By greeneyes21 in forum MacReplies: 3Last Post: 21st Jan 2010, 21:05 -
iDVD and subtitles
By Sgaar in forum MacReplies: 4Last Post: 4th Jan 2009, 23:37 -
No Audio in iDVD
By The Monkees in forum MacReplies: 8Last Post: 12th Feb 2008, 19:35 -
MPG's in iDVD
By The Monkees in forum MacReplies: 12Last Post: 10th Jan 2008, 18:56
