Greetings all.
My daughter's Polaroid portable DVD player is dying.
With a DVD, after around 30-35 minutes of play or 5-7 chapter forward skips, the picture freezes and the motor stops spinning the disc.
The same happens with CDs, obviously without picture freezing.
I bought a Memorex lens cleaner but the player won't recognize the disc.
Any idea why it will not play any disc past a certain point?
How can I clean it if it won't recognize the disc?
Is this thing toast? Any way to bring it back from the dead?
Any help you folks can be will be greatly appreciated!
Thank you in advance.
There is nothing to recognize on cleaning cd...there is no data to read. You put it in, the player spins the disc trying to read it, and while it is spining, the brush cleans the lens.
Sounds like hardware failure in the tracking mechanism. You could put it in the shop and get it fixed, but it is almost certainly cheaper to buy a new one.Google is your Friend -
Were it mine: I'd start shopping for a replacement.
There were also some guys on the net who replaced lasers and serviced portables - but I believe they focused on Panasonics (which cost much, much more than Polaroids - making it economically feasable).;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep" -
One other thing examine the bottom of the discs. You wouldn't believe it but I get poeple that come because their cdroms wont work. You pull the disc and it looks like melted chocolate or jelly or tone fo fingerprints. Spritz with windex, wipe and they play. BTW most of these players will stop spinng the disc when the laser can't read the disc.
An easy test if you can find the interlock for the door open. If you defeat it you can actually see the laser through the disc. try several discs and see if they all die at the same spot. Look without a disc, see if something is blocking the lasers movement. Lots of these cheapo players you can see through the drive into the compartment.
The other thing if these are copies try originals and see what happens.
Portable DVD Player vs Portable Video Player
By DJboutit in forum Newbie / General discussionsReplies: 9Last Post: 2nd Dec 2012, 17:28 -
Lenco portable dvd player DVP-931 MPEG4 playback problem.
By edh in forum Video ConversionReplies: 5Last Post: 13th Jun 2010, 04:58 -
Advice on portable DVD player problem
By suriogl in forum Newbie / General discussionsReplies: 1Last Post: 28th Aug 2008, 02:53 -
Problem with Scott DPX i730 portable dvd player.Please help !
By Runner206 in forum DVD & Blu-ray PlayersReplies: 7Last Post: 27th Aug 2008, 04:49 -
Portable DVD Player Audio/Video Unsync Problem
By wicious in forum Newbie / General discussionsReplies: 0Last Post: 18th Jul 2007, 08:14
