my roomates APEX UK2A-C1 dvd/tv combo unit is all off a sudden locked.
im not sure how it happened, i just found it that way one day.
but the only thing that works is the power button on the remote, and we cant use it for anything at all.
the only thing that it does is show a little picture of a lock if u press any button.
i searche dgoogle but cant find anything
Hi again, Ted!
Try the APEX support forum for any similar issues. Sometimes these remotes can get screwy if doused in water accidentally (as happened to my son's remote!) or left near a high heat source.
I took my son's remote apart and cleaned it thoroughly with alcohol and a cotton swab, allowed the individual pieces to dry for a day then reassembled the entire mess. Once I replaced the batteries, viola! It has worked for 4 months and counting so far, and nothing quirky has happened with it since.
God luck to you guys!
TTWC"I've got a present for ya!" - TTWC
Lacie Cinema: Can't power device on using remote but will power on with USB
By truequant in forum Media Center PC / MediaCentersReplies: 1Last Post: 14th Nov 2011, 03:03 -
Responding to remote button presses in DVDAuthorGUI
By Asja in forum Authoring (DVD)Replies: 3Last Post: 28th Jun 2010, 20:05 -
DVDLab Pro VMG and Menu Button and Chapter Skip on Remote
By raouliii in forum Authoring (DVD)Replies: 2Last Post: 20th Dec 2007, 13:08 -
How to enable the program button on remote control using VIDEO_TS.IFO
By kraw in forum Authoring (DVD)Replies: 4Last Post: 26th Sep 2007, 21:59 -
Stopping Skip button on remote from showing hidden videos (GUIforDVDAuthor)
By kojow7 in forum Authoring (DVD)Replies: 1Last Post: 8th Jun 2007, 16:19
