I have a video in Premiere Pro 1.5 that I need to encode to put on youtube. The problem is that I can't find the right settings that will make my video look clear on youtube (I've already tried many settings).
My video is from my Canon miniDV camera, so it starts out as a .AVI when it is captured on Premiere Pro.
When encoding the video, what settings would be best for youtube?
Note: my video was shot in 16:9 widescreen and I am editing in a 4:3 with the video scaled down to 75% so that it fits the 4:3 box with black bars on top and on the bottom (because youtube uses 4:3, not 16:9).
I resize mine to 320x240 in Virtualdub , then I encode to .FLV with FLV Encoder before I upload to YouTube. If I want better quality on YouTube crank up the bitrate in FLV Encoder but I've given up on that. What comes out at YouTube's end is never consistent.
Anyone else? I use Premiere Pro 1.5. What settings should I use with PREMIERE PRO?
YouTube's gonna re-encode it to .flv anyway.....but another tip I heard was simply make it the best quality you can in WMV but keep it JUST under the 10 minute, 100MB max...unless you have a director's account on YouTube.
None of the tips I've heard involve Premier Pro. -
Exactly it will just be re-encoded anyway. Which brings up a point. Why encode to flv?
As said resize down to 320x240 since it will be resized to that anyway. Same goes for the audio. Just match whatever specs they use in terms of framerate, resolution, audio sample rate, channels, etc. -
My vids that I encode to .flv beforehand are available to the public to view in half the amount of time for the vids I did in Xvid....that is the main reason why I use/recommend .flv first.Originally Posted by celtic_druid
Youtube HD 1080p settings? Youtube conversion out of sync!
By DoubleJMan in forum Video ConversionReplies: 12Last Post: 5th Jan 2010, 02:04 -
Best settings for vegas pro 8.1 and youtube.
By ingeborgdot in forum Video Streaming DownloadingReplies: 16Last Post: 27th Nov 2009, 20:50 -
Best HD settings output from Adobe Premiere for Youtube...
By mhdeaton in forum Video Streaming DownloadingReplies: 4Last Post: 12th Nov 2009, 00:15 -
YouTube Premiere Settings - High Definition Fine Tuned
By Priapism in forum Video Streaming DownloadingReplies: 14Last Post: 9th Sep 2009, 14:13 -
Encoding for uploading YouTube. Best settings with Adobe Premiere Pro 1.5?
By vid83 in forum Video Streaming DownloadingReplies: 2Last Post: 5th Dec 2008, 20:27
