    May 2007
    Is there any program that will check a DVD for errors/read errors? I want to go back and check the dvd's I've made and see if there are any glitches in them, but I don't want to watch them all. I've had some people borrow some and then bring them back and say it had problems, so I want to check them out and burn new copies if they have problems. Any help is much appreciated, thanks.
  2. Member rvelez's Avatar
    Oct 2005
  3. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    DVD Info Pro does essentially the same thing. Either are good.
    Read my blog here.
  4. Member blutach's Avatar
    Apr 2007
    Australia
    In order to get the full story, however, you will need a drive with "statistics" - ie one which outputs PIE/PIF data.
    Regards
    Les
