I did a Windows Update this morning, and now when I stick a movie DVD in the drive it always brings up a menu of the files/folders. It used to start Intervideo, VAIO's DVD playing program. I started that and looked at the settings and the autoplay check box is greysd out and also Intervideo is not in the options box of the drive properties. What should I do!?
You could start by verifying AutoPlay in the drive settings. Open the drive properties for you dvd drive, go to the AutoPlay tab, and check what is chosen.
Your best bet would most likely be to choose "Restore Defaults" and then reboot. Next time you insert a DVD, you should then get a prompt and you can choose which app to use.Google is your Friend -
I was in there and messed with it. I will try the restore to defaults as you said during lunch. Strange thing was that the usual programs were there for autoplay like windows media player, and real player. But Intervideo was not there. I wonder if the updates messed with something. Double clicking on the IFO file in the VIDEO_TS directory started Intervideo so it is still there and set for this file type.
Thanks -
Its back to normal now. Rebooting was the trick. thanks Krispy. www.youtube.com/gwoiler
Codec won't work with Vegas
By Jon.G in forum EditingReplies: 1Last Post: 26th Sep 2011, 07:52 -
Mov to mp4 won't work
By Klagar in forum Video ConversionReplies: 1Last Post: 15th Dec 2010, 11:07 -
Why won't my mic work on my camcorer?
By apples017 in forum Capturing and VCRReplies: 3Last Post: 12th Jun 2008, 05:05 -
cd drive rw won't work
By sue1951 in forum ComputerReplies: 6Last Post: 27th Aug 2007, 13:39 -
ffmpegX 0.0.9x r2 just won't work under X.3.9 ?
By Jose Hidalgo in forum ffmpegX general discussionReplies: 1Last Post: 16th Jul 2007, 08:37
