I snagged an MKV file and used a Windows-based extractor to get the raw H264 file, but I can't figure out how to convert it to AVI. All I want is the video, so I couldn't care less about the audio.
How do I do this? ffmpegX isn't doing jack with it.
Is this a Mac question or a Windows question? If it's Mac, I can move you to that forum.
avc2avi isn't just a windows app. Should compile fine under OSX. You will find avc2avi.c in x264's tools directory.
mkvtoolnix is also available for OSX: http://www.bunkus.org/videotools/mkvtoolnix/macosx/mkvtoolnix-1.6.5.pkg.tar.bz2 so no need to use windows there either. -
Have you tried to use my wonderful friend's app,
Merkonk's MoKgVm2DVD, on the mkv file?
or perhaps Visual Hub?"Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User
Need to batch (or queue) convert raw h264 file to mp4
By dukestravels07 in forum Newbie / General discussionsReplies: 10Last Post: 29th Mar 2015, 12:45 -
muxing raw h264 with raw g711 to mp4 continer
By niror in forum Newbie / General discussionsReplies: 5Last Post: 23rd Aug 2011, 12:25 -
Need to convert raw .h264 stream to edit in Vegas Pro 9
By cintec in forum EditingReplies: 18Last Post: 9th Aug 2009, 13:44 -
How to create .mp4 file by using raw .h264 and .aac files for JW Player
By hakkinen in forum Newbie / General discussionsReplies: 2Last Post: 10th Mar 2009, 21:49 -
What do I do with a raw .h264 file extracted from an .mp4 container?
By godfist314 in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2008, 13:51
