Hi,
I have some training vids that were encoded for me using Xvid and now I need to convert them to MPG2 for use on a DVD. The problem is when I encode them, with TMPGenc, the resulting MPG videos are upside down. I have to use the absolute highest quality settings in TMPGenc and am not sure where to even begin troubleshooting this.
I have the latest XVid and Divx codecs installed, XVid is registered as the default codec for these and otherwise I use Jockersots Codec Installer/Checker to make sure I have whatever codecs I need.
Any hints on what the issue is would be greatly appreciated!
Joe
Results 1 to 19 of 19
I'd try a different program. DVD Flick is worth a look- freeware and gives excellent, quick results:
https://www.videohelp.com/tools/DVD_Flick
I'd also suggest WinAVI, but that isn't freeware
Ok, I will try those.
I did run CodecInstall and it said the video codec was corrupt so I reinstalled XVid. Unfortunately it had no effect.
Thank, -
You can set the XviD codec (Configure decoder) to flip the video. This may be checked (or may have to be checked).
/Mats -
As I said I use Codec Installer v.2.2.0.0 and Install Codecs as needed. Here is what is installed for video now:Originally Posted by 45tripp
AVI Decompressor
AVI Draw Filter
Color Space Converter
DivX Decoder Filter
DivX Subtitle Decoder
DMO Wrapper Filter
ffdshow MPEG-4 Video Decoder
Indeo® Video 4.5 Decompression Filter
Indeo® Video 5.11 Decompression Filter
Microsoft MPEG-4 Video Decompressor
Microsoft Screen Video Decompressor
MJPEG Decompressor
MPEG Video Codec
Nero InteractiveGraphics Decoder
Nero PresentationGraphics Decoder
Nero QuickTime(tm) Video Decoder
Nero Thumbnail Decoder
NVIDIA Video Decoder
Overlay Mixer
QT Decompressor
VGA 16 color ditherer
Video Port Manager
Windows Media Video Decoder
XviD MPEG-4 Video Decoder
Joe -
Flip video was not checked and checking it did nothing.Originally Posted by mats.hogberg
ffdshow may be doing your XviD decoding. I'd imagine there's a "flip" option for that too? Yes, it is - Configure Decoder.
/Mats -
You can drag your file into graphedit to see what is decoding.
Tmpg plus?
Don't understand why people still use this...
Common suggestion for any trouble is to move directshow plug in to highest priority in enviromental settings
might want to try removing all xvid, ffd and divx, then adding xvid only first and so on. -
And graphedit to see decoding filters?
and changing direcshow priority in tmpgenc?
For starters Tmpg Xpress.Originally Posted by joelore
I like and suggest the use of HC.
i've had video and audio processing separate for a long time now so I use it on it's own, typing out the avisynth scripts i need.
but you could try it with a number of frontends. -
"And graphedit to see decoding filters?
and changing direcshow priority in tmpgenc?"
Yep, did those as well. Something is very borked on my system. After removing everythng and resintalling FFDshow graphedit shows the file being filtered through AVISplitter then FFDShow but still it comes out upside down.
What do I need to mux the MPV & WAV files from CCE? That is quick and very good quality.
Thanks, -
You add the mpv and wav when you author the dvd. I don't think it possible to put mpv and wav in a basic mpg file.
Try convertxtodvd for this. It will do what you want at the same quality if not better and faster then TMPGenc in my opinion. It's way faster and easier to use. I would also remove the divx codec since there is really no need for it if you have the xvid codec. it handles divx fine.
Convertxtodvd is a quick and dirty tool, good if your in a hurry or for watch once files but for getting the best quality it absolutely ******* sucks, saying it is better than tmpgenc is like saying vcd is better than dvd or a black & white tv is better than a colour one.Try convertxtodvd for this. It will do what you want at the same quality if not better and faster then TMPGenc in my opinion
convertX is very good for a 'one step' solution
NOT everybody wants to jump thru multiple HOOPs to convert something that is not going to be a permanent ENJOYABLE archive
my daughters 'baby videos' need the best work i can do
a throw away copy of a training vid on 'how to suck up to the boss' does not not need that kind of time an atention
everybody has different needs and different standards
Problem with Mp4cam2avi converting to XviD AVI
By twister6 in forum Video ConversionReplies: 11Last Post: 25th Jun 2010, 01:09 -
Problem converting HD (.mkv) to DVD (.mpg2) with TMPGEnc
By KPKMP33 in forum Video ConversionReplies: 4Last Post: 9th Nov 2007, 09:36 -
Strange problem converting local show to mpeg2.
By jcm0320 in forum Capturing and VCRReplies: 1Last Post: 7th Aug 2007, 00:15 -
Converting AVI to xvid AVI - Audio Sync Problem
By foochuck in forum Video ConversionReplies: 3Last Post: 4th Jul 2007, 23:22 -
Problem Converting AVI to xvid AVI (using AutoGK)
By foochuck in forum Newbie / General discussionsReplies: 2Last Post: 3rd Jul 2007, 09:57
