ffmpegx and Turbo.264
My guess is that it will work with the "decode with quicktime" setting. Has anyone tried it? Its supposed to significantly improve encoding time.
http://www.elgato.com/index.php?file=products_eyetvturbo&PHPSESSID=cf1b861f24b14eddd55531f991406c2f
It actually works with "quicktime aware" applications such as iMovie. I thought the "use quicktime" setting in ffmpegx would work but I am not sure it will use the turbo.264 extensions in quicktime.Originally Posted by Case
Unfortunately the handbrake guys said it might never work because it uses open source extensions.
It looks like it has a bit more flexibility...Originally Posted by Case
http://www.notebookreview.com/default.asp?newsID=3766
...but with obvious limitations of only working within the prescribed programs. Has anyone tried the product and compared it with ffmpegx?
-fate
Yes. I have the turbo.264. It is really pretty fast. I have a 2.16Ghz MBP and I see almost double the encoding speeds. I've had it encoding at 60+ fps before. any app that has the quicktime export options will work with it. I've tried it with imovie, compressor, and eyeTV. But I hardly use it at all anymore for a couple of reasons. The settings are very limited. it only comes with 3 presets, ipod, ipod large, appleTV, with NO advanced settings. there is no way that I've found to be able to tweek the settings even a little bit. The other big down-side to the turbo is that the video quality isn't that great. Colors seem slightly washed out and in darker scenes it has a greenish tint that seems to flicker on and off. very annoying. I'm not sure what avc codec it is using, but the results are no where near the quality of encoders like ffmpegx and visualhub which use the x264 codec. it could be that the settings just need to be tweaked and optimized. hopefully a firmware update will fix this soon. I probably wont be using it until there is another update to the software or the firmware.
That's a good report ammonkc.
It sounds like ffmpegx is still on top with regard to quality and flexibility. I need more options with my "aging" G4 and G5's
-fate
PS check your PM's if you get a chance.
Any hw accelerated h.264 encoder for windows like Elgato turbo.264 HD
By chicken264 in forum Video ConversionReplies: 3Last Post: 14th Apr 2011, 17:22 -
turbo.264 issues
By marksch in forum MacReplies: 0Last Post: 9th Mar 2008, 20:46 -
ffmpegX and PSP h.264
By str in forum ffmpegX general discussionReplies: 4Last Post: 25th Feb 2008, 09:08 -
turbo.264
By mhar4 in forum MacReplies: 4Last Post: 7th Sep 2007, 11:55 -
Turbo.264 USB Stick Hardware Encoder
By willrob in forum MacReplies: 12Last Post: 26th Jun 2007, 00:58
