Just bought this portable LG DVD player and I need a multiregion hack. It is the LG DP781. I tried using the older model hacks on this one, but zero joy.
Why would you buy a DVD player needing a hack for it when no such hack yet exists?
Not all DVD players are hackable!
Good luck though ...
This file worked for me on my new LG HT-302SD, when no other trick worked...
It's worth a try
http://aiwaownersnetwork.tripod.com/pages/lg/lg5000.zip
Unpack the zip file and burn the folder to a disc, i used Nero...
1. Burn the folder 'RMTM0000' to a CD-R making sure that the directories stay in order.
2. Insert the disk to your player
3. It loads..... After a few seconds it opens the tray
4. And a Region Select menu will come up.
5. Press "0" on the remote for multi-region. Then press the pause key.
How to hack the LG RH387
By tracy77 in forum DVD & Blu-ray RecordersReplies: 19Last Post: 6th Sep 2023, 05:46 -
un-hack a hack?
By hnw in forum DVD & Blu-ray PlayersReplies: 9Last Post: 9th Jan 2011, 10:30 -
dvd hack
By kneten in forum DVD & Blu-ray PlayersReplies: 3Last Post: 27th Aug 2010, 13:49 -
Can't seem to get hack right: LG BD 370
By rjl24 in forum DVD & Blu-ray PlayersReplies: 9Last Post: 3rd Jun 2010, 07:53 -
Hack help
By broleh in forum DVD & Blu-ray PlayersReplies: 1Last Post: 15th Oct 2007, 09:52
