  1. Hello. I made a menu with a picture and a music file. When I play it in my Norcent dvd player it plays the music on the menu fine. When I play it in my Sony dvd player it skips and never gets to play the music that I put on the menu. I do have the settings set so everything including the menu is converted from Pal to Ntsc. Any ideas how I could fix this? Should I leave in Pal?
  2. What audio format are you using for the menu?
    Try checking "Encode video to audio duration" under settings.
    Dwight
    "A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
    - Herm Albright
    www.martialconcepts.com
