Ive used various guides programs etc over time to capture and author DVDs and lately moving to HD playback. Ive listed my way of doing it(!) below, based on my experience and trial and error, and I hope it helps others. (At least it will help me to remember how to do it).
One point to remember, I have no interest in speed of processing. Overnight is fine. Im only interested in a quality product. Some will say that they can get as good using lesser settings, that has not been my experience, and Ive processed a lot!
My target is to play back DVD on any DVD player/TV/monitor/PC setup and to play back the HD on a 32 LCD. The times gives are based on my setup, the speed will completely depend on your processor speed.
Ok, first the capture.
My hardware setup is a Sky+ box directly connected to my video card (an old pinnacle card) and sound inputs on the PC.
Software required is VirtualDub, with the Huffy codec installed.
Step by step as follows:
 File  Capture AVI
 File - Set Capture File and give it a sensible name
 Video  Preview
 Video  Preview acceleration  Both fields so you can see what you are doing!
 Video Capture Pin  Compression UYVY and output size 720 x 576. NTSC may require a different size, but use the biggest.
 Video  Compression  Select Huffyuv, and configure predict median and predict gradient
 Calculate roughly the length in seconds of the programme to be captured.
 Capture  Stop Conditions  and enter the time in seconds calculated for the capture time exceeds. This is strictly necessary, but it means you can set it going and forget about it.
 Now when youre ready, Capture  Capture Video.
 The files will be big, about 20GB per hour.
Next the cleanup:
Load the file back into VirtualDub. Edit out the commercials etc. Depending on your PC setup, you may have to adjust the sound. On mine it lags the video by about 120ms. Audio  Interleaving and set the delay audio track by -120 (in my case). Play around with it until you get the setting to suit your setup.
 Video  Direct Stream Copy
 Audio  Direct Stream Copy
 File  Save as AVI give it a name and off you go.
It should take about half real time to complete. You now have a file you can convert to DVD MPEG2 and or Divx for HD.
Lets make a DVD.
Buy TMPGEnc Plus for this step. Its the best, simple and cheap.
 File  Project Wizard
 (1/5) select your format. In my case, PAL. Select VBR MPEG-1 Layer II Audio (MP2).
 Next
 (2/5) select your edited file.
 Next
 Other Settings
 Video Tab
o Size . 720x576 (or NTSC size). Rate Control Mode . 2-Pass VBR (VBR). Encode Mode . Non-interlace. DC Component Precision . 10. Motion search precision . highest quality (very slow).
 Advanced tab
o Sharpen edge . Set horizontal and Vertical to 70 and enable the filter. Trust me its worth it.
 Ok
 Next
 For a full size file, set the % to 96%, otherwise, set the video bit rate to 6000
 Next
 Give it an output name and Ok.
 It will take at least 4 times real time, but its worth it. The file will be 4.1GB.
When its finished burn it with your DVD authoring software (I use TMPGEnc Author, but any will do). Put in menus if you want (hence the 96% above!)
Ive a 32 LCD TV and I wanted to get the best playback, using a recorded source, as above, played back from the connected PC. Using the Huffy file above would be very good, but the file is too big. Divx is the only real option. Follow the steps below and the result is a very good quality 4-6GB file (better than the DVD above). I keep them on-line on a 1TB NAS, but you can burn them onto a DVD.
Buy the Divx pro codec. Its cheap and well worth it.
Using VirtualDub
 File  Open video file the cleaned up Huffy above.
 Video  Full processing mode
 Video  Filters
Add  HSV Adjust and set the Saturation to x92%
Add  Sharpen and set to 20
Select the sharpen filter and press the Cropping button
If there are black bars above and below, increase the Y1 and Y2 offsets by up to 85 each. Total offset must be divisible by 2.
If there are bars left and/or right, increase the X1 and X2 offset to remove them, but the amount must be divisible by 4.
 Ok.
 Ok
 Audio  Direct stream copy
 Were going to do a 2 pass Divx compression.
 Video  Compression  select Divx 6.5.1 Codec  select Configure
Main Tab  High Definition Profile
Rate control Mode - Multipass 1st pass
Bit rate  I use about 5100, use the calculator to check, but dont have it less than resulting in a 4GB file.
Codec Tab  tick enhanced multithreading and select Adaptive Multiple consecutive for the coding
Video Tab  Custom size 1280 x 720 (to suit the 32 screen). Resize filter Bicubic (sharp). Interlace  progressive source. Output Pixel - Square 1:1.
 Ok. Ok.
 File  Save as AVI  name it and tick dont run this job now
Main Tab  Rate control Mode - Multipass Nth pass (dont change anything else).
 File  Save as AVI  same name and tick dont run this job now
 File  Job control. Youll see 2 jobs there, press the start button.
It will take about 4 times real time.
The output can then be played back on your big screen from the PC, and it looks very good.
Hope this helps.
				Results 1 to 1 of 1
  How To Produce High Quality WMV from AVI / DVD Files?By devilcoelhodog in forum Video ConversionReplies: 3Last Post: 24th Jan 2010, 22:13
  high quality VOB filesBy nji899jus in forum Newbie / General discussionsReplies: 29Last Post: 15th Oct 2009, 09:32
  Programs to Produce Very High Quality FLV Output FilesBy devilcoelhodog in forum Video ConversionReplies: 2Last Post: 25th May 2009, 01:10
  Low size, high quality WMV filesBy devilfruit in forum Video ConversionReplies: 2Last Post: 29th Jan 2008, 18:08
  I need a high quality DVD BurnerBy efb91 in forum Authoring (DVD)Replies: 4Last Post: 25th Sep 2007, 17:38
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
