I recently decided to change the way I'm storing my DVD's. I am now storing my DVD's in plastic sleeves that hold 2 DVD's each. I was wondering after I began the changeover if it's the right thing to do. Is the soft material that is touching the data side of the DVD OK for long term storage? Will heat cuse the material to damage the data? Does anyone have any info on DVD storage that could help me?
Ken
I've been storing my DVD's like this for some time without a problem. Where would the heat come from? Any disc can be affected by excessive heat so I would avoid it. As long as the disc isn't getting scratched, then it should be okay and that goes for BOTH sides of the disc, not just the data side. Sometimes it is worse if you scratch the label side.
Converting DVD's for HDD storage
By rocks911 in forum Video ConversionReplies: 0Last Post: 11th Oct 2011, 14:28 -
DVD Storage Cases
By Tenacguy in forum MediaReplies: 6Last Post: 10th May 2010, 18:43 -
Best storage media for audio (long term storage)
By The Sumerian in forum AudioReplies: 6Last Post: 6th Mar 2010, 11:15 -
DVD Storage Solution ?
By xobituaryx in forum MediaReplies: 2Last Post: 7th Feb 2009, 23:00 -
Is optical media storage more stable than magnetic media storage?
By bevills1 in forum ComputerReplies: 24Last Post: 5th Apr 2008, 04:32
