Hi,
I have a 1280x720 avi file. If I play it on my computer the aspect ratio doesn't look ok. This is made to look good on a 16x9 tv I think
I want to resize the movie to ? x 720 so that it looks ok.
Anybody know which is the number to use for the width?
thanks!
what do you mean it doesn't look OK ?
it should be letter boxed , with blk bars top & bottom, so that round objects 'wheels' etc.. are round and the people look correct , NOT to thin
if it is filling your screen and the people look to thin, and tires look like tall ovals
then use the menu of your player software and change the display VIEW / aspect to 'default OR 16:9' so that it displays correctly
if you want to fill a 4:3 screen with out distortion, either zoom in on the video "player menu' or re-code the video cropping off the sides of the picture to make it more sq
the first way gives you the same picture as the second way , but you don't have to do any work , or destroy the video file -
I'm not trying to play it full screen, it is just that the avi file is a flat 1280 x 720 and I want to reduce the width so the faces don't look too wide.
To give you an example, if I make an avi file from a regular dvd I get a 720x480 avi that I resize to 640x480 so that the correct ratio is ok when played on a computer.
But with a 1280 x 720 what is the correct resolution to resize? Something like 1200x720 I guess? I would like to know the correct resolution to use.
If I had a hd dvd drive I would stick an hd dvd movie in it and look at which resolution PowerDvd shows it to me so that the faces aren't looking wide. -
You're confusiing 2 different but related things: Square vs. Nonsquare pixels, and Anamorphic vs. Letterboxed vs. Fullscreen display.
720x480 is Nonsquare. Going -> Square = 640x480. IF your 720x480 was 4:3 AR and NOT 16:9. If it was 16:9, you should convert to 853x480 for square pixels.
OTOH, 1280x720 is SUPPOSED to be square pixels already! AND 16:9.
You --shouldn't-- need to do any converting, unless the bloak what converted/saved it 1st did it wrong.
If it's wrong, there's NO way of knowing for sure what it was SUPPOSED to have been. We might be able to do a decent guess if you could post a screenshot, especially one with people and/or "circles" in it.
Scott -
have you tried using VLC player, it has more viewing aspect ratio settings than most players, including 16:10 and 5:4 wide screen 22
there should be a setting there that will let you watch the video with out the peoples faces being to wide, is suspect you need to make the aspect taller by using 16:10 for watching them or perhaps 5:4
but try VLC and try all the different play aspect viewing/display ratios
DVD screen to 1280 * 720 (Handbrake)
By Hydra in forum Newbie / General discussionsReplies: 4Last Post: 7th Jan 2012, 04:13 -
mixing 1280 x 720 29,97 fps and 1440 x 1080 25 fps in final cut
By perik in forum EditingReplies: 6Last Post: 17th Nov 2010, 23:42 -
tmpgenc xpress auto resize results in 708 width in 720 frame.
By davexnet in forum Video ConversionReplies: 0Last Post: 27th Jan 2010, 14:49 -
1366 by 768 vs 1280 by 720-difference?
By bigshotceo in forum DVB / IPTVReplies: 5Last Post: 25th Dec 2007, 00:04 -
How to Convert 1280*720 DivX to a less dimensions DivX
By firas_hashim in forum Video ConversionReplies: 9Last Post: 27th Jun 2007, 09:33
