I rip a chapter with mac the ripper, open it in ffmpegx and hit encode. Audio codec is set to AC3, bitrate to 224, Sampling to 44.1 and channels to 5:1, mode VBR. Track is set to 0. Video codec if you need to know is set to AVI (mencoder). This is the output:
Opening audio decoder: [liba52] AC3 decoding with liba52
AC3: 2.0 (stereo) 48000 Hz 224.0 kbit/s
AUDIO: 48000 Hz, 2 ch, s16le, 224.0 kbit/14.58% (ratio: 28000->192000)
Selected audio codec: [a52] afm: liba52 (AC3-liba52)
This is actually good. The source is 2.0.
I then select track 1, change nothing else. The output is:
AC3: 5.1 (3f+2r+lfe) 48000 Hz 448.0 kbit/s
AUDIO: 48000 Hz, 2 ch, s16le, 448.0 kbit/29.17% (ratio: 56000->192000)
Using MMX optimized resampler
The selected video_out device is incompatible with this codec.
Try adding the scale filter, e.g. -vf spp,scale instead of -vf spp.
(AC3-liba52)
Why is the video codec incompatible? Why does this cause a revert to 2.0 when the source is 5.1?
I select the third audio track, track 2. The output is:
MPEG: No audio stream found -> no sound.
Track 0 is Digital Dolby 2.0. The next is DD 5.1. The third is DTS. I already know Mac users have never heard of DTS so I forget about that. But I can at least enjoy DD 5.1 or is that unheard of too? Even if I select passthough I get 2ch only.
This program is really getting on my nerves. What can I do to fix this?
Thx in advance for any help.
mencoder currently only supports stereo ac3 in AVI. As far as I know, this hasn't changed since the date of that post. Try "AVI (ffmpeg)" instead.
movie with two ac3 2-channel audio tracks one is mono, which one?
By pm1315 in forum Authoring (DVD)Replies: 1Last Post: 25th Oct 2011, 14:14 -
Edit AC3 tracks losslessly?
By digitalfreaknyc in forum AudioReplies: 7Last Post: 17th Feb 2011, 10:20 -
Video with L/R tracks to DVD with 2 channel audio tracks
By Downloader in forum Authoring (DVD)Replies: 2Last Post: 22nd Aug 2010, 02:56 -
Editing & joining AC3 tracks
By carlmart in forum EditingReplies: 1Last Post: 18th Apr 2010, 13:06 -
m2v and ac3 multiple audio tracks to DVD
By gameroftheuk in forum Authoring (DVD)Replies: 7Last Post: 4th Aug 2008, 16:55
