    Jan 2006
    Will a memory stick card reader read memory stick pro media? If not, are memory stick pro card readers available? I'm considering buying a camcorder that uses memory stick pro media as well as tape and was wondering if I'd need another card reader for the memory stick pro media.
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    I don't believe so. I have an older generation sony digi cam that won't read mem stick pro but works only on mem stick. I'm sure that would be the same situation with a mem stick basic card reader.
    You can get new card readers really cheap especially if you check for rebate deals. I'm sure the newest ones include support for mem pro.
  3. Member wwaag's Avatar
    Jan 2002
    Olympic Peninsula, US
    I've got an older card reader that works fine with the newer memory stick Pro. The Pro usually comes with an adapter which will fit into a regular memory stick slot. You simply plug the Pro into the adapter which in turn fits in the regular memory stick card slot. That works with a number of card readers that I have. If all else fails, just get a new card reader that handles virtually any card--often less than $10. Good luck.
    wwaag
