Undoubtedly, this has been asked several times before, but I could not locate a thread on it (so pardon any redundancy). I have been making Mini DVDs of family life with my camcorder for years and now I want to download those memories onto my home computer hard drive to then burn them onto DVDs. How do I do that? Thanks in advance...
https://forum.videohelp.com/topic276230.html?highlight=mini dvd dvd
Check this or if you want more than do search on "All Forums" under "Mini DVD to DVD". There are tons of threads on this matter. -
It depends what kind of mini dvds. WHat files do you see on the disc?
If it's a standard dvd with a VIDEO_TS folder and vob files then you can just copy the video_ts folder and burn it on a dvd. If you would like to join several dvds use tmpgenc dvd author.
If it's a DVD_RTAV folder with vro files then use tmpgenc dvd author or dvd ulead workshop to make a new dvd.
Transfering contents from one DVD to another?
By whatever911 in forum Authoring (DVD)Replies: 3Last Post: 23rd Feb 2012, 11:49 -
extracting 2 dvd contents to burn to single DVD
By perfection in forum Authoring (DVD)Replies: 1Last Post: 18th Jul 2009, 09:26 -
Merging the contents of 2 DVD into 1
By txl in forum Authoring (DVD)Replies: 4Last Post: 7th Oct 2008, 08:24 -
Unit to convert mini dv to dvd?
By mikehende in forum Newbie / General discussionsReplies: 4Last Post: 9th Jul 2008, 12:07 -
How Do I convert DV mini cassett to DVD?
By mndngo27 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 2nd Nov 2007, 00:51
