I have successfully used HDTV2DVD in the past. I wanted the ability to create DVDs with multiple titles so I registered a copy of SVCD2DVD. I have a few basic questions:
1. How can I create a text item on the menu that is not selectable. For example I am creating a DVD with 3 episodes of Planet Earth and I want the DVD menu to look like this:
2. How do you remove the "Play All" button.Code:Planet Earth Episode One Episode Two Episode Three
3. How can I get access to the 2.5 Beta.
Thats all for now. This seems like a great program. I'm looking forward to making lots of DVDs. Thanks.
Jay
1. You need to make a background image containing any static text you want, then add it to the project.
2. The "Play All" button should only be added manually. If you have added it and want to remove it, you will need to start your project over.
3. Drop ChrissyBoy a PM.Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com -
1. Indeed: Just throw the background you wish to use into Paint/PaintShopPro/Photoshop etc add your "static" text and save. Then use the "background" button on the menu screen in SVCD2DVD to use it.Originally Posted by Jikchung
2. If you add it by mistake - click the "Play All" button again and it will go.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
2. That's one I didn't know - thanks Chris!
Dwight
- Herm Albright
Thanks to both of you for the help. I have an additional question after using the product today:
Is there a way to specify a temp directory. In my case the source files are on a NAS device. I noticed that SVCD2DVD created a temp file for each asset (i.e. filename_S2D.mpg) in the same directory as the source files. If I could put the temp files on a local disk it would likely improve performance. Thanks for the great program.
Jay -
Unfortunately at this time there is no way to specify a temp file. I would move the source files to the local disk if that is an option.
Dwight
- Herm Albright
New AVStoDVD user got some questions this software
By rock_king_my in forum Authoring (DVD)Replies: 8Last Post: 16th Sep 2010, 19:05 -
Vegas Pro 8 user with questions about program (and possible camera settings
By chuchunezbie in forum Newbie / General discussionsReplies: 0Last Post: 27th Apr 2009, 17:32 -
New user
By Ppeter in forum ffmpegX general discussionReplies: 11Last Post: 21st Mar 2009, 07:16 -
User Right
By Johnnylee_hang in forum ComputerReplies: 2Last Post: 12th Jun 2008, 04:11 -
Linux questions from a Windows/OS X user
By LSchafroth in forum ComputerReplies: 18Last Post: 3rd Apr 2008, 00:36
