We have numerous PAL VHS tapes and DVDs that we would like to preserve on standard NTSC DVDs. I have tried very hard to rip the PAL DVDs and convert them properly but this process is very complex, particularly for a non-professional.
Question is: I have a multisystem VHS player and a multisystem DVD player that play the PAL media perfectly on NTSC televisions (so obviously a PAL-to-NTSC conversion is happening on the fly). Shouldn't I be able to capture these streams of converted video/audio to MPEG2 (or other compressed) format and then author a regular DVD?
If the answer is yes, what are the hardware/software pieces that I need? For example, is all I really need a USB video capture device that will convert an analog video signal to MPEG2 on the fly (i.e., for the DVDs, plug the S-Video out on the multisystem DVD player into the video capture device)? Many thanks!
Unless you paid somewhere between $300 and $500 for that VCR....it is not a true "converting" VCR...it is only a multisystem one and it is not outputting a true NTSC signal.....it is outputting a quasi signal which is almost impossible to "record". Some computer capture cards can handle quasi signals but even those are few and far between.Originally Posted by joelkranz
This is a true converting VCR:
http://www.bombayelectronics.com/vcr/mx100.html
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 12:33 -
How to convert a PAL VHS into NTSC VHS or DVD?
By coody in forum Video ConversionReplies: 9Last Post: 22nd May 2011, 03:09 -
Capturing NTSC tapes on PAL VHS and DVR
By ramrod1234 in forum Capturing and VCRReplies: 0Last Post: 23rd Oct 2009, 22:08 -
Capturing NTSC VHS tapes to PAL Final Cut...
By willed in forum Capturing and VCRReplies: 2Last Post: 22nd Jan 2008, 17:48 -
Pal VHS to NTSC DVD
By je9694 in forum Newbie / General discussionsReplies: 2Last Post: 24th Sep 2007, 09:57
