I am trying to convert an AVI file into H.264 format through Quicktime Pro. I have successfully exported four other large files, but the last file is causing problems. In the first attempt the conversion would make it about 8 percent in and then give me an "unknown error" message. The beginning of the footage dropped some frames in the AVI, so I cut those out and created a new AVI file for the conversion. Again the file made it about 8 percent through before giving me the "unknown error message". I re-captured the footage from DV and tried once again to use Quicktime Pro to convert to H.264. This time the conversion made it 98% through at at the very end i received an error message saying "-36 I/O error occurred". Wondering if anyone could help me out as to what the source of the problem may be.
Thanks,
John
You might also want to try a different encoder such as x264. Should be able to open the mp4 in QT once done and export (no re-encoding) as a mov.
QuickTime Pro exporting image sequence with the frames in the wrong order?
By adam-tl in forum Video ConversionReplies: 2Last Post: 29th Nov 2011, 15:55 -
Final Cut Pro, gives me GENERAL ERROR when exporting to Quicktime
By Huntr777 in forum MacReplies: 8Last Post: 30th Sep 2011, 14:26 -
quicktime pro will exporting to h.264 solve this huge file size issue?
By cybershot in forum Newbie / General discussionsReplies: 7Last Post: 10th Oct 2010, 21:43 -
problem with conversion from quicktime to h.264.
By savvyguy in forum Video ConversionReplies: 23Last Post: 19th Jan 2009, 20:49 -
Quicktime Problem: Playing and Exporting
By hzgg2 in forum Video Streaming DownloadingReplies: 1Last Post: 20th Jul 2008, 15:48
