Ok, I've run into a confusing situation. I have some progressive video files, and I would like to author them to DVD. Everything seems fine, but my DVD playback software is still reading the DVD as an interlaced source.
The original AVI files are progressive, so I ticked the "progressive source" box in CCE so that the MPEG flags would be correct (and they are).
But everytime I author a DVD (doesn't matter which program), the DVD reads as an interlaced source. I don't think this is right, as I've seen many commercially released DVDs that read correctly as a progressive source.
I thought this would be easy to fix by using IFOedit and changing the flag, but it won't let me! When it gives the choice between "camera" and "film", it's stuck on camera and the film option is darkened out and not selectable. It's driving me crazy. All I want to do is change the DVD's flag to progressive.
Any tips?
Hi-
Just what is reading it as an interlaced source? You have to understand that every NTSC DVD outputs interlaced 29.97fps, no matter how it was encoded and stored on the DVD. It could very well have been encoded as progressive 23.976fps, but with the 3:2 pulldown, the result is interlaced 29.97fps output. You can run the vobs through such programs as ReStream and Bitrate Viewer to confirm that the progressive flag has been set.
What authoring program are you using? You're sure that a progressive 23.976fps source isn't being reencoded as interlaced 29.97fps before authoring, aren't you? You did apply 3:2 pulldown so it's DVD compliant, didn't you, either during or after the encoding? -
The original content is 29.97 fps (NTSC) and 25 fps (PAL). It is standard definition content made progressive by motion-adaptive deinterlacing.
I just noticed that when I viewed the info with PowerDVD, it still says "interlaced". However, when I check the info for some Hollywood movies, it will say "progressive".
I ran some of my VOB files through Bitrate Viewer as you suggested, and it says they are progressive. I guess that means things may be ok, but why do some "professional" DVDs read as progressive on my DVD playback software? -
Yes, I'm finding it by following the "configuration" option.
I'm using version 7.0, can't remember what the older versions are like.
Authoring DVD from AVCHD source
By cheerful in forum Authoring (DVD)Replies: 5Last Post: 2nd Mar 2010, 12:36 -
Please, help to convert progressive source to interlaced result
By lovyagin in forum Video ConversionReplies: 11Last Post: 6th Oct 2009, 11:57 -
changing the resolution without streeeetching the source
By midnait in forum EditingReplies: 14Last Post: 7th Jan 2009, 22:40 -
Interlaced source encoded as progressive?
By MagicSparky in forum Video ConversionReplies: 3Last Post: 19th Dec 2008, 17:30 -
Changing field order flags = losing chapter points.
By gadgetguy in forum Authoring (DVD)Replies: 2Last Post: 5th Jan 2008, 12:13
