Strange problem when converting Xvids to DVD using Mainconcept, if virtualdub shows that the audio is in sync then after conversion it is always out. I have to save the audio as a seperate file and load it into Mainconcept. If Virtualdub says the audio is out then the resulting DVD is perfectly in sync. ffdshow is the only codec loaded
Roy
VD will not tell you if a file is in sync or not -- and playing it in VD is not a good way to check sync .... specially if a vbr mp3 or ac3 file
TV Capture with EasyCAP and VirtualDub Audio out of sync
By olobay in forum Capturing and VCRReplies: 9Last Post: 29th May 2011, 18:19 -
audio sync issue with virtualdub
By tommcd64 in forum AudioReplies: 1Last Post: 18th Oct 2007, 14:09 -
audio not sync with virtualdub :(
By N3kr0 in forum EditingReplies: 0Last Post: 21st Jul 2007, 12:07 -
VirtualDub Audio Sync Issue?
By hech54 in forum EditingReplies: 2Last Post: 10th Jun 2007, 04:41 -
VirtualDub unable to keep audio sync'd on *source* audio
By falconne in forum Newbie / General discussionsReplies: 1Last Post: 29th May 2007, 06:12
