  1. Member cyflyer's Avatar
    May 2004
    London uk
    On a couple of dvd's that I burned some time ago on the standalone recorder, say title 1, title 2, title 3, all titles visible but last title refuses to play. Stick the disc through dvdShrink and I get "invalid navigation structure", stick in decrypter and it shows status: incomplete. These recordings are where I stuck a vhs clip on, then another etc, then finalsed the whole thing at the end. What could I have done that won't allow the last title to be read, even though its there ? Is there any way to recover it ?
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Typically, the problem would be a disc that isn't finalized. But in that case, you can usually access the last title burned and not the previous ones. In your case, it sounds like a hardware malfunction or bad media. In either case, the video is most likely not recoverable.
    Google is your Friend
  3. Not sure what's causing that problem. I've used Isobuster on unfinalized defective discs made on a Pioneer 510 and it's been able to recover nearly all the material on the disc.
